A/c compressor clutch not engaging
Old Jul 31, 2010 | 08:44 PM
sean_t0's Avatar
Hi, I have a 2003 g35 sedan. i went to turn on the a/c and noticed hot air was blowing out. i pressed the a/c button the button lights up, but still hot air. so i went to check refrigerant level and it was good, replaced the relay and noticed no engagement of the clutch. then when i supplied 12v power straight to the compressor the clutch engaged. anyone know what to do from here? any help would be appreciated. thanks.
Old Aug 2, 2010 | 04:21 AM
sean_t0's Avatar
bump
Old Aug 2, 2010 | 08:46 AM
NFSP G35's Avatar
? = 2B || !2B
You absolutely sure about the refrigerant level?
IDK about the G, but one of my previous cars wouldn't engage the clutch if the refrigerant level was off.
If the level IS right, I guess there might be a chance it's the pressure sensor and the car thinks the level is wrong, even though it's not... just theorizing.
Old Aug 2, 2010 | 02:39 PM
sean_t0's Avatar
yeah level should be correct. checked it a couple times with the gauge that came with the refrigerant. do you know where the pressure sensor would be on this vehicle?
Old Aug 2, 2010 | 03:18 PM
NFSP G35's Avatar
? = 2B || !2B
No clue.
Sorry man.
All I can say is try looking up and down all the A/C lines.
Old Aug 2, 2010 | 04:27 PM
azt108's Avatar
The same thing happened to me and I had my AC 'recharged' and it's fine now. It would click on and then click right off. I dropped $70 at a local shop on it. Worth a try...
Old Aug 12, 2010 | 02:27 PM
harrisot's Avatar
You probably already know that our cars don't use the compressor clutch the way other cars do. The swash plate construction inside the compressor takes care of variable operation rather than cycling the unit on and off the way a clutch would. Our clutch should be engaged if the AC system is on and there is sufficient refrigerant.
My system disengages periodically as it detects a pressure fault - it is just attempting to protect the compressor. Irritating but hardly worth the cost of repair yet.
Old Jun 25, 2019 | 08:00 PM
jemcdono333's Avatar
G35
Low pressure switch is shown on this You tube video
Old Sep 16, 2023 | 02:13 PM
my vehicles's Avatar
2004 infiniti Grey
How can charge AC if clutch doesn't run?
Old Sep 17, 2023 | 10:57 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Bypass the low pressure switch with a paperclip.
G35Rican
Jul 31, 2024 01:37 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
mattdg35
Sep 14, 2015 11:28 AM
