creaking from rear windows...
Old Aug 18, 2010 | 07:53 PM
lpchristilaw's Avatar
the noise is driving me nuts. It's the worst when I accelerate and sometimes when I break/ go over bumps. It's like a creeking sound, and if the windows are opened just a fraction of an inch it doesn't happen... any suggestions guys?? Thanks
Old Aug 18, 2010 | 10:58 PM
mcaron's Avatar
i got the sameeeeee problem, so dam annoying
Old Aug 19, 2010 | 08:34 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's a TSB for this, you only need to replace a couple of small bolts with slightly smaller bolts.
TSB ITB05-034
Old Aug 19, 2010 | 02:37 PM
RADIOGUY21's Avatar
yeah the fix is replacing the bolts in the rear doors. If under warranty have the dealer do it.
Old Aug 19, 2010 | 02:58 PM
thescreensavers's Avatar
Mr.202?
Yep there is a TSB for it
You can buy all 4 bolts for like 3 bucks at the dealer and DIY its an easy job
Original Bolt on the left, TSB Bolt on the right
DIY Guide
https://g35driver.com/forums/body-in...l-removal.html
Old Aug 19, 2010 | 09:34 PM
OKStateG35's Avatar
I would just DIY it so you can put threadlock on the bolts the first time. I had to redo mine a month after the dealer worked on it because they didn't use any.
rezendvous420
May 31, 2020 01:26 PM
snic09
Nov 8, 2017 01:46 PM
tiguy99
Mar 1, 2016 11:42 AM
nineiron
Sep 10, 2015 12:08 PM
iknowitsfast
Aug 12, 2015 02:08 AM
