NO AC and out of town! need help
Old 08-29-2010, 06:31 PM
B T's Avatar
B T
B T is offline
My AC was working fine thsi morning, got back in the car and the compressor won't fire up. I checked all the fuses I know of, kickpanel andbehind the battery. I'm 500 miles from home and have to drive 100 before work in the morning.
Blower works
Stereo works
all controls seem to work fine
no cold air at all
2006 G35 Sedan
Old 08-29-2010, 06:43 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,487 Likes on 1,222 Posts
Do you have an aftermarket intake? Check the aluminum AC tube on the driver's side of the engine for wear. Pop chargers will rub a hole in that tube if the tube's not protected with something. That would let the refrigerant out while the rest of the system appears to work correctly.
Here's more info: https://g35driver.com/forums/intake-...e-ac-line.html
Old 08-29-2010, 06:45 PM
B T's Avatar
B T
B T is offline
no, but i have a jacked up core support, that could very well be the issue, was rubbing a few months ago
Old 08-29-2010, 06:55 PM
Blue Dream's Avatar
Gives you a starting point to look at then.
Old 08-29-2010, 09:01 PM
Johnnyone's Avatar
man that sucks i rode around a few wks in the middle of summer without ac, so i feel ur pain
My ac clutch went out around 105k miles, not sure what could cause urs to go out but GL.
Old 08-30-2010, 08:20 AM
blazeplacid's Avatar
how much 134-a is in the system?
if the level is to low the compressor wont turn on
Old 08-30-2010, 08:29 AM
B T's Avatar
B T
B T is offline
don't have a gauge on me to measure, i guess that'll be my first step this afternoon. I checked ALL my fuses last night and didnt find anything wrong. Maybe the compressor clutch?
Old 08-30-2010, 02:15 PM
B T's Avatar
B T
B T is offline
got the level checked today at a shop, refrigerant level is good, but the mechanic couldn't tell me if it was the switch, climate control module, or compressor clutch that was bad, guess I'm taking it to dealership unless anyone else has some ideas
Old 09-08-2010, 03:28 PM
B T's Avatar
B T
B T is offline
still no AC
Old 09-08-2010, 05:53 PM
Blue Dream's Avatar
WTF, has the dealer looked at it??
Old 09-09-2010, 09:15 AM
B T's Avatar
B T
B T is offline
No, I have had bad enough experiences at the local Infiniti stealership, waiting to take it to the Subaru place to get the work done at discount by a friend. anyone ever order parts from http://www.discountacparts.com ?
Old 09-16-2010, 04:47 PM
B T's Avatar
B T
B T is offline
Got plugged in at the dealership, quick diagnosis and had the airbag recall done at the same time. The A/C went out due to a cracked pressure switch which caused a break in the circuit and released some refrigerant to the atmosphere. part was only 68 bucks, but the scan was $108
Old 09-16-2010, 05:14 PM
Mustang5L5's Avatar
Was just gonna chime in and suggest checking the pressure switches. Guess I am too late.
Old 09-16-2010, 05:46 PM
Johnnyone's Avatar
not sure what the pressure swith looks like but i had this line go bad on me, for those that experience this issue in the future. The line goes from compressor to condensor.
Old 09-21-2010, 09:48 AM
B T's Avatar
B T
B T is offline
Got my Core Support in yesterday, and have been searching for any threads about replacement. Anyone have an idea of how long this takes?
Quick Reply: NO AC and out of town! need help
