Maybe the ECU needs periodic resets?
Old Sep 8, 2010 | 12:39 AM
DaveB's Avatar
For the past few months my car has felt a bit doggy and I chalked it up to high temps and humidity. Shifting felt a bit off and throttle response was laggy. My 6 y/o OEM battery had been showing signs of death for about 3 months as well (ie really hard and slow starts). I replaced the battery on Saturday and was shocked at how much more responsive the throttle and tranny were. There's no way a dying battery can affect a car while running, right? I use to laugh at people that reset their G and Z ecus every 2 months or so to restore response and power, but now I'm wondering if there is some truth to it.
Old Sep 8, 2010 | 01:43 AM
pinkii's Avatar
my battery died when I was driving. Scary experience. So yes it can affect a car while its running.
Old Sep 8, 2010 | 02:15 AM
socalwdup's Avatar
My car battery died after not turning it on for a month. But it was the OEM battery and needed replacing anyways.
Is this normal? On a cold morning in California, it takes my car longer than usual to start the engine. Or could it be spark plugs...
Old Sep 8, 2010 | 04:04 AM
boostedforlife's Avatar
If the battery dies while your driving the car should still be able to run. Now if ur alternator goes out at the same time then ur screwed
Old Sep 24, 2010 | 03:13 PM
Abax84's Avatar
I just did my first ECU reset last week and did notice a small difference, but what are you thinking would be the benefit of resetting frequently? I dont reinstall Windows every couple of weeks on my computer, only when things start to slow down. Unless you are noticing a difference in performance or shifts, why reset?
Old Sep 24, 2010 | 03:52 PM
Mustang5L5's Avatar
Over time, the car "learns" fuel strategies. What is has is called "Short Term Fuel Trim" and "Long term fuel trim". If you have an OBD2 scanner with live data, you can see these numbers real time.
STFT takes the instantanous O2 sensor readings and adjusts A/F ratio. Usually it's within 10% of a specific known value. Overtime, if the computer noticed your STFT is lean or rich, it will adjust the LTFT to keep the average ratio within center range. In other words if it notices your short term mixture is rich, it will adjust your mixture for a leaner mixture over time.
Once dialed in, you get optimum fuel economy. When you reset, you wipe out everything your car has learned and start fresh, which sometimes results in a "peppier" feel until the car relearns fuel strategy over the next few weeks.
It also forces the car to relearn A/T shift strategy as well.
Old Sep 24, 2010 | 03:56 PM
azt108's Avatar
oh man, you people do anything to feel like you have more power!
Old Sep 24, 2010 | 04:30 PM
NFSP G35's Avatar
? = 2B || !2B
^Though strictly speaking, A computer will run really good with a fresh install of windows every couple of weeks
Old Sep 24, 2010 | 05:49 PM
Mustang5L5's Avatar
I don't do it. I'd rather have the fuel economy.
Old Sep 24, 2010 | 11:57 PM
DaveB's Avatar
It really has nothing to do with power, but there is no doubt the throttle and tranny is more responsive right after a reset. Power wise, I can't tell any difference. Throttle tip-in and shift firmness under part throttle shifts is much better. I've tried the reset twice over the past 3 weeks now. Same result. But like others have said, gas mpgs go in the tank. I loose about 15% mpg on the reset. I've know this for years. My old VQ30 did the same thing. Another problem is I drive pretty sedately 90% of the time so the ECU and TCM quickly learn my driving style within a week so the throttle response becomes a bit deadened and tranny shift firmness except at WOT is softened. It's not horrible by any means, but I'd much prefer the initial throttle and shift firmness feel all the time.
Old Sep 25, 2010 | 02:09 AM
TurTLe*'s Avatar
does clearing the ECU via scan tool work the same way as resetting via battery cables?
i do the ECU clearing when i get bored. I know by clearing it LTFT and STFT are reset. Tranny probably still remembers
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
