DIY beginning of wire tuck
Old Mar 1, 2013 | 01:42 AM
  #196
guitarrocker98's Avatar
Ban ^^^^^^^^ again.
Old Mar 1, 2013 | 03:17 AM
  #197
Looks like the guy I was referring to either deleted his comment, or got the boot. His links just send you to amazon crap.
Old Mar 2, 2013 | 07:02 AM
  #198
So when you did this, did you screw new holes for the negative cables? Also, if your going to put your hood pin back on you need to extend out that wire.... It won't reach otherwise. But back to the negative cables... Did you screw new holes or did you extend them out and put them back where they were?
Old Mar 2, 2013 | 05:16 PM
  #199
midnytegsedan's Avatar
I extended any negative cables that needed to be extended and put them back in the same spot.
Old Mar 2, 2013 | 06:33 PM
  #200
Thanks I appreciate the response. I just wasn't sure which to do haha. Both will take about the same time.
Old Mar 4, 2013 | 11:33 AM
  #201
Monday morning bump for main wire harness tuck diy
Old Mar 10, 2013 | 05:31 PM
  #202
Question why delete the washer hose and resivoir? Kow it cleans everything up, but do you all just take it out and completely delete it? How would one clean up that side? I've searched but found nothing on this, but I also haven't read through all the 50 plus pages on cleaning up bays.
Old Mar 10, 2013 | 08:08 PM
  #203
G35Papa's Avatar
^Most cleaning up the bay just remove the filler tube. It just pulls out, then cap the resivoir with tape or you can get a rubber pipe cap from a hardware store.
Old Mar 10, 2013 | 08:09 PM
  #204
G35Papa's Avatar
DIY main harness tuck, compliments of SN00P
https://g35driver.com/forums/media-s...ness-tuck.html
Old Mar 10, 2013 | 09:21 PM
  #205
TORETTO's Avatar
cant tell if spammer or actual appreciative member.
Old Mar 10, 2013 | 09:25 PM
  #206
Frankieg35's Avatar
Can't u put the washer tank behind the grill or sumtin??
Old Mar 10, 2013 | 09:31 PM
  #207
Frankieg35's Avatar
He posted in a bunch of threads..
Old Mar 11, 2013 | 01:50 AM
  #208
S then do people just leave the resivour there and when they need to add fluid, they uncap the top and fill it? That's my question really. And I'm debating on doing the main harness tuck, lots of splicing on that one, and I'm not fantastic on soldering..... So I dunno if I'm going to tackle that one. Plus I have a turbo and there are a few more wires in mine than most.
Old Apr 1, 2013 | 02:53 PM
  #209
Tedisky's Avatar
How you routing the drivers side harness past the A arm after you make a hole in the wheel well?
Old Apr 12, 2013 | 08:15 AM
  #210
MPG35fiend's Avatar
sbd plan on doing this soon..
