5AT Grounding kit question
Old Jan 2, 2011 | 09:03 AM
SpForces's Avatar
Ok, Looking around I have seen lots of people saying that the grounding kits help with some of the quirkiness of the 5AT transmission. My question is, do you really need the whole kit or would the one wire strung the to the tranny do the same thing. Forgive me if this is stupid. I am a noob electrician
Old Jan 2, 2011 | 09:23 AM
liljohnny's Avatar
Grounding kits = snake oil, don't bother!
Old Jan 2, 2011 | 09:57 AM
Mustang5L5's Avatar
I've always added 1 supplemental ground wire to engine to my cars. Since this is the first auto, I would also add one to the trans.
Ground kits add multiple wires. I just do 1 or 2 and make it myself for a couple bucks. I used to be an electrician....so I have wire and crimps and the tool kicking around
Old Jan 2, 2011 | 10:27 AM
bluedevils95's Avatar
What's the difference between just 1-2 wires vs. 10 wires? I ordered a kit and it comes w/ 10 wires. 1-2 would do the job?
Old Jan 2, 2011 | 11:23 AM
Swivel's Avatar
Moderator
Based on first-hand personal experience?
Old Jan 2, 2011 | 01:16 PM
Mustang5L5's Avatar
A dozen wires is unnecessary IMHO. Running a ground wire from intake manifold to various point of the engine seems overkill considering the entire engine is metal and bolted together with metal fasteners. Most sensors on the engine carry their own grounds, so grounding the block really is so the spark can fire from the center electrode to the aluminum head. A good block or head ground would make a difference here. Most of the engine is aluminum, filled with coolant that also conducts electricity well, so all that I feel is needed is a solid block to chassis ground.
I've usually done one solid engine ground from block to chassis and another solid ground from trans to chassis. (on cars with electronic trans)
Supplemental grounding doesn't hurt at all, so doesn't hurt anything to do it. I just don't feel all 10 wires are needed.
Old Jan 2, 2011 | 02:36 PM
SxExCx's Avatar
I have sold almost 400 kits and the feedback is 100% positive. DO you think THAT MANY people can be fooled?
Read the reviews and PM me if you are interested.
https://g35driver.com/forums/reviews...es-review.html
Old Jan 2, 2011 | 03:08 PM
ccc123pm's Avatar
X
Im still waiting on a solution to get the grounding wire to the trans on the AWD, as the front driveshaft seems to block the "suggested mounting point"... any help sean?
https://g35driver.com/forums/engine-...ing-wires.html
Old Jan 2, 2011 | 03:26 PM
liljohnny's Avatar
Yup!
Old Jan 2, 2011 | 03:45 PM
How any wires is your kit?
Old Jan 2, 2011 | 03:55 PM
4D05G35's Avatar
Originally Posted by Mustang5L5
Well more wouldn't hurt, but it's unnecessary IMHO. Running a ground wire from intake manifold to various point of the engine seems overkill considering the entire engine is metal and bolted together with metal fasteners. Most sensors on the engine carry their own grounds, so grounding the block really is so the spark can fire from the center electrode to the aluminum head. A good block or head ground would make a difference here. Most of the engine is aluminum, filled with coolant that also conducts electricity well, so all that I feel is needed is a solid block to chassis ground.
Pretty much what he said. I opted to make my own grounding wires because I was skeptical and didnt want to spend $100 on something that I can make for under $20.
I forget how many wires I made, but as Mustang5L5 said you dont need 10 wires running all over the place. Just re-enforce the main grounds and you are good to go. I have noticed quicker/more responsive shifting in my 5AT and thats what I wanted to accomplish.
Old Jan 2, 2011 | 04:16 PM
Mustang5L5's Avatar
Exactly. The point i am trying to make is that they work, but you don't need dozens of wires. You don't really need to run a supplemental ground from the intake to the timing cover, or head to timing cover. Just do block to chassis and trans to chassis. If you wanted to go overkill, you could even do individual heads to block/chassis and maybe a new battery cable. But usually parts mechanically fastened together are grounded pretty well.
A quick search of eBay and you can find plenty of pre made wires in different wire sizes and lengths. Just figure out what mount points you want to use and estimate how long of a wire you'll need. I prefer 2 or 4 ga wire.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Jan 2, 2011 | 05:56 PM
4D05G35's Avatar
Exactly. I used 4g wire. I opted to just buy a few ft of cable, connectors, and shrink so I could make them the exact length I wanted. I wanted them to follow the existing wires and concealed nicely.
As you said, you can add more, it wont hurt, but it also wont benifit you. It just makes for more wires to hide.
Old Jan 2, 2011 | 06:09 PM
thescreensavers's Avatar
Mr.202?
There is some merit to what liljohnny said, Only way to find out is to measure the stock wires resistance + how much of a voltage drop at the different stock grounding points.
So far I do not think anyone has done a thorough scientific testing of the stock grounding wires/points.
Until then, I wont be spending money.
Old Jan 2, 2011 | 07:57 PM
Mustang5L5's Avatar
I wouldn't say it's snake oil. They certainly don't hurt at all But but if you understand how vehicles are usually wired, you can see you don't need 10-15 wires. In fact, I'd bet that ONE good block to chassis ground would be sufficient and improve shift function as well. I don't even think a trans ground is needed either. Most engine and trans electrical doesn't ground to the engine/trans, it grounds to the chassis, so improving the chassis to block ground will help reduce resistance as most vehicle batteries are grounded to the engine block.
One good block to chassis ground wire would run you $10 off eBay.
Of course, it would help to make sure all your current electrical connections are good and clean. This includes all current grounds and wiring as well as battery terminals and cables.
