Ignition
Old Mar 16, 2011 | 09:18 PM
we<3infiniti's Avatar
Ignition
Well here's the deal, I bought an 04' infiniti g35x. The car has just over 100k miles on it but the price was well worth it. Anyway, it takes a good 5-7 seconds to start up and I must say it's quite embarrassing considering it is a beautiful looking car. Also, I took it to a mechanic and he said it may be the spark plugs or the fuel pump. This mechanic wasn't on my A list but hey, it was a free diagnosis. I also read somewhere that it could be something with my intake? I need some advice. Is there any way I could actually tell what it is? Thanks
Old Mar 16, 2011 | 11:46 PM
LuXXXz's Avatar
could be ****ty gas put some fuel stabilizer/cleaner in there, it happens to me when i get gas from a ****ty gas station even though its premium always
Old Mar 17, 2011 | 03:26 PM
I don't think that's the culprit reason being I can gas from multiple different gas stations. Do you think it could be anything else?
Old Mar 17, 2011 | 03:46 PM
srv2nv's Avatar
G35 Sport
Change the piugs, you're probably due, and I would definitely change them since you bought the car used. Run some cleaner through the car, as it could be gunked up injectors as well.
If that doesn't help, start looking into other things, like the pump, etc.
I just find it beneficial for the car, and you, to do a few small maintainance things like that whenever you buy a used car, as its usually something people over look when they're about to trade in/sell.
Old Mar 17, 2011 | 03:50 PM
Thanks for your help, I will try the spark plugs first.
Old Mar 17, 2011 | 09:10 PM
infinitig35's Avatar
Maybe try a brand new battery also.
Old Mar 17, 2011 | 11:34 PM
LuXXXz's Avatar
why would you start plugs first!
start cleaner first, plugs doesnt take 4 minutes
Old Mar 18, 2011 | 08:46 AM
srv2nv's Avatar
G35 Sport
Because he's at 100k miles, so he's due for a new set of plugs anyways, so why not take care of those while you're doing everything else?
It will also give you a little bit of an idea as to how the car was taken care of before you had it.
Old Mar 18, 2011 | 09:31 AM
drkay's Avatar
+1 on the plugs and cleaner. But try battery as well, maybe get it tested first. I have an 04 and just changed the battery and it starts a lot quicker. Mind you mine didn't take 5 secs to start but start time significantly improved.
Old Mar 18, 2011 | 11:48 AM
ridinG's Avatar
Another +1 on the battery. My battery got discharged and every startup after that took like 3-5 seconds of turning over before it started. New battery, starts up instantly.
junon
Jan 14, 2023 09:37 PM
mike730
Jan 12, 2018 04:25 PM
mtlruss
Dec 20, 2015 01:51 PM
pasjr1972
Sep 1, 2015 10:17 PM
.cakestar
Aug 4, 2015 09:05 PM
