Tire size question.
Old May 6, 2011 | 03:45 PM
JustFly's Avatar
Tire size question.
I just bought the M45 sport twin spoke 19" wheels for my 2003 Sedan. I know they are 8.5" all around. I want to put 225/40/19 tires on the front and 255/40/29 tires in the back. Will the 255 tires work? Will I need a spacer? Im also planning on lowering the car a bit, I have skunk 2 springs.
Thanks
Old May 6, 2011 | 04:06 PM
The-Dream's Avatar
I would be 245 on the rears personally. However 255 should work yes.
Old May 6, 2011 | 05:25 PM
JustFly's Avatar
Reason I'm looking at the 255 is because it is a local deal that I want to jump on.
Old May 6, 2011 | 05:32 PM
4D05G35's Avatar
The rear tire will be 1" larger than the front if you go with 255/40/19.
Something to consider prior to purchase.
Old May 6, 2011 | 06:27 PM
infinitig35's Avatar
That should look pretty hot. So how much were those M45 wheels?
Old May 7, 2011 | 07:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Your tires would be .9" different and the diameter will be 3.4% off which may or may not cause issues with the VDC. Conventional wisdom says stay under a 3% difference F/R to be safe. 255/35 would be a better fit for the rear or 245/40 for the front as well. I understand you have a specific option, but if it were me I wouldn't pull the trigger.
Old May 7, 2011 | 12:58 PM
JustFly's Avatar
turns out that the rears are 255/35/19 and the fronts are 225/40/19. Does this sound better?
Old May 7, 2011 | 01:00 PM
Blue Dream's Avatar
Yep, that's perfect. You should have no issues with those sizes as I mentioned above.
Old May 7, 2011 | 01:29 PM
JustFly's Avatar
Thank you, I really appreciate it.
Old May 7, 2011 | 01:46 PM
4D05G35's Avatar
Yep those are perfect sizes. I ran those before with no issues.
*edit*
I just re-read that the wheels are 19x8.5. That 255/35 is probably going to be too wide due to the width and profile.
I would go with a 245/40/19 all around instead.
Old May 8, 2011 | 01:06 PM
JustFly's Avatar
*edit*
Really?! Well I bought the 255/35/19 tires for the rears so I hope they fit.
Old May 8, 2011 | 01:10 PM
The-Dream's Avatar
I'm actually about 4% larger than stock. I run 255/40/19 front and 285/35/19 rear.
Old May 8, 2011 | 01:47 PM
Blue Dream's Avatar
Those will fit no problem on an 8.5" rim, but will look very meaty. The sidewall will stick out farther than the edge of the rim due to the width.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
