2003.5 sedan...and a mechanical fan?
Old May 19, 2011 | 01:09 PM
ryanm8's Avatar
I never really paid much attention to this earlier, but I just recently changed my belts out and noticed that I have a mechanical fan (attached to the pulley) instead of electrical. I thought only the early 03 doggy-door sedans had the mechanical fan? Anyone else with one?
Old May 19, 2011 | 01:34 PM
Mustang5L5's Avatar
The changeover may or may not coincide with the 2003 and 2003.5 change over. Really tough to say what goes on on the assembly line. I've frequently seen other makes of cars come off the line with incorrect equipment as well.
Old May 20, 2011 | 02:43 PM
GGGGGGGG's Avatar
2004.5 sedans have electric fans, but you can definitely buy aftermarket electric fan kit for yours.
Old May 20, 2011 | 02:46 PM
DaveB's Avatar
All 6MT sedans have e-fans.
Most all 03-04 5AT sedans have mechanical fans. Some later 04 5ATs snuck in with e-fans.
All 04.5 sedans have e-fans.
Old May 21, 2011 | 12:34 PM
ryanm8's Avatar
Ah, thanks for the info DaveB. I was hoping that my sedan wasn't an early 03 with the trunk replaced or something
Old May 25, 2011 | 12:25 AM
NFSP G35's Avatar
? = 2B || !2B
^Easiest and best way to tell for sure is to check the plugs on your ECU
Old May 25, 2011 | 06:06 AM
ryanm8's Avatar
Yeah I checked and I have the gray plug And all this time I thought I was safe since I didn't have a doggy door. What a bummer.
Has anyone done an e-fan conversion using an OEM assembly?
Old May 25, 2011 | 09:18 AM
NFSP G35's Avatar
? = 2B || !2B
^I haven't yet, but plan to.
The e-fan out of a older Nissan Quest or Mercury Villager (same vehicle) are a perfect size for the OEM fan shroud.
Old May 25, 2011 | 09:38 AM
ryanm8's Avatar
Interesting. So that's a different fan than the G35 e-fans I assume? Does it have a single fan or dual?
Old May 25, 2011 | 09:56 AM
NFSP G35's Avatar
? = 2B || !2B
Single fan, dual speed.
Old May 25, 2011 | 10:30 AM
ryanm8's Avatar
Keep us updated on your conversion. I'm very interested in doing this as well.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
mattdg35
Sep 14, 2015 11:28 AM
