suspension question~newbie
Hey I got these springs from my buddy's 350z...Can someone tell me if they are revised / unrevised.
Also, do I just pretty much just swap them in for my non sport oem sedan springs? And will a alignment be necessary?
Sorry for the newbie questions, i did search and found out that i did not need a camber kit or toe bolts..Still looking for these answers though!
thanks.
thanks.
So, unrevised.
with a 1 inch drop, u will still be able to get ur car aligned. u shouldnt have much issues with camber wear, if any.
i had the same springs on my g35x. alignment wasn't bad. i did camber arms font and rear. if i had to do it again i would have saved up and got a quality aftermarket set up. just my 2 cents.
Sorry I missed this thread earlier.
Yes, those are unrevised. Also, you don't need a camber kit with Z springs.
Tell the shop to use alignment specs for a 350Z and you'll be fine.
I have a little neg camber that puts it just slightly out of sedan specs, but my tires aren't showing any camber wear after a year.
Would probably depend much on the tire, and how good a job the alignment shop did. I know some guys on here run excessive negative camber, but don't wear tires as fast as you might think because they keep their toe as close to perfect as possible.
rezendvous420
May 31, 2020 01:26 PM
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
kinetek
Aug 3, 2015 04:25 PM
