V35 G35x AWD general information, FAQ, helpful links
Old Nov 27, 2012 | 11:20 PM
  #46
ccc123pm's Avatar
X
^ right on, will add some brake info to page 1 when i get a sec. Other things to think about is wheels. stock 17's can clear brembo's but need a small spacer due to +45 offset...
Old Nov 28, 2012 | 06:42 AM
  #47
ArkansasG35COUPE's Avatar
I would like to know about spacers as well. Looking for a flush look, but couldnt find anything on spacers for the X... Any suggestions? I am thinking 15mm all the way around! Let me know...
Old Nov 28, 2012 | 08:39 AM
  #48
ccc123pm's Avatar
X
spacers is not an issue unique to AWD. It has more to do with what size wheel and tire, as well as the offset of the wheel. You need to determine your desired offset and buy spacers accordingly. RWD guys should be able to help you on this one as well
Old Nov 28, 2012 | 09:40 AM
  #49
FlyingLumpia's Avatar
I run spacers on my car. I have ran 25 on my stock 17's
Old Apr 23, 2013 | 09:43 AM
  #50
yosip1115's Avatar
Crap! What exactly stops tokico blues or D spec shocks from fitting an X?! I already bought some blues with tein S techs, and just read this? Freakin me out guys. Info please:
Old Apr 24, 2013 | 11:59 PM
  #51
The rears will fit, the front wont. Two different mounting points. Sorry you should return the blues.
Old May 8, 2013 | 03:22 AM
  #52
G_DiRTY5's Avatar
I hate to sound like a noob but I need a definite answer for my buddies 06' G35x, he recently got a flat tire in the right rear wheel and that tire cannot be repaired since the hole is in the sidewall. So the question is can he just replace 2 rear tires as opposed to all 4?
I told him he should be fine because the car is 4WD not AWD, but I just need to make sure. Thanks in advance!
Old May 8, 2013 | 03:38 AM
  #53
jeggo's Avatar
As long as the new ones will be the same size I don't see why not.
Old May 8, 2013 | 03:45 AM
  #54
G_DiRTY5's Avatar
I forgot to mention that he's buying his tires from a used tire shop so they might not have the exact same tires. Also I figured tire wear might be an issue lets say for example the rear wheels have less tread on them therefore the wheels would be spinning slightly faster. Wouldn't that cause the 4WD to kick in and possibly make it run at all times or more often than it should?
Old May 8, 2013 | 07:54 AM
  #55
G2B35AGN's Avatar
^^^ that is correct. He is in for four new tires.
Old May 9, 2013 | 04:24 AM
  #56
jeggo's Avatar
I agree with not using 4 different tires but I am running different brand fronts and rears but with the same sizes and I don't have any problems with my X.
Old May 10, 2013 | 04:43 AM
  #57
G_DiRTY5's Avatar
Thanks buddy, this is exactly what I needed to know. I'll let him know you just saved him some money.
Old May 16, 2013 | 01:35 PM
  #58
North NJ G's Avatar
Would a wheel with certain specs and offsets on the rwd look the same on the awd?
Old Jun 12, 2013 | 09:38 PM
  #59
ccc123pm's Avatar
X
updated front right axle information
http://www.mypartsgarage.com/cardone...t-60-6282.html
Old Jun 12, 2013 | 09:57 PM
  #60
G2B35AGN's Avatar
Just a heads up. Sorry to be slow on the comeback.
The key phrase here is "with the same sizes." Sure it would be fine if you have different brands same size front and back as long as the wear on the tires is the same.
My understanding from your description of the issue is that he wanted to keep worn fronts and put new rears on. That means even if the sidewall says they are the same size, they are not the same outside diameter due to the wear on the fronts.
And that's a problem with the AWD. It is my understanding that will put extra strain on the transfer case as the sensors detect different rotational speeds.
Last edited by G2B35AGN; Jun 12, 2013 at 10:15 PM. Reason: Got my fronts and rears mixed up....
