Help fuel pressure loss on crank
Old Dec 14, 2011 | 08:33 PM
GOAT35's Avatar
I'm not a mechanic and I've searched for days because I hate to start new threads. Anyways my G has no pressure on crank. I turn the key and I hear the pump buzz but when I try to start it I hear the starter (works fine) but takes about 3-5 turns of the key before it starts. When it does start the car vibrates hard for a few seconds but stops after I give it gas. I think it might be the fuel pump or the regulator but don't know how to test. The stealership says a new pump cost 460 dollars......i can barely pay my tuition right now......
If anyone knows what it might be please reply......also if an ebay product can solve this problem please let me know what it is/seller/link...anything is appreciated. Thanks guys
Old Dec 16, 2011 | 08:13 PM
GOAT35's Avatar
Anyone???
Old Dec 16, 2011 | 08:28 PM
butkiss1's Avatar
Check out this thread I started a while back.
https://g35driver.com/forums/engine-...own-motor.html
Old Dec 16, 2011 | 08:34 PM
butkiss1's Avatar
Ck fuel pump /regulater.
I threw in a used Walbro pump.
I also have my AFR checked out regularly as well.
Old Dec 17, 2011 | 09:46 AM
GOAT35's Avatar
You just scared the hell out of me with that!!!! Car will be parked until problem is fixed because that sounds tooooo similar. THANK YOU!!!
Old Dec 17, 2011 | 03:51 PM
supreme1911's Avatar
Yes it can be the rings. What you need to do is a compression test for all 6 of your cylinders. Theres threads that will show you how to do one, its quite easy. This will help you single out which is the trouble maker. When you find that one (or two, I hope not) cylinder that has low compression, put some motor oil into that bank then crank again. If it shows normal compression similar to the other cylinders AFTER you put the oil in it, then its the RINGS.
were you burning oil too?
Old Dec 17, 2011 | 11:01 PM
GOAT35's Avatar
Idk but tomorrow I have a full day of testing because I cannot afford a new engine right now! Ill search up the thread hopefully I can dig it up. Thanks for the tip!!!
Old Dec 18, 2011 | 11:31 AM
butkiss1's Avatar
Keep us posted.FYI I picked up a used engine with 52,000 miles for 1200 dollars.
your also very lucky because your fuel problem did not allow you to drive the car which means you didn't do much damage to it. I don't think it would be piston ring issue, sounds like a fuel problem plain and simple.
1. Fuel pressure test.
2. Try to find a scanner and have your AFR checked.
3. Don't panic .sounds like an easy fix it's really easy to have your fuel pressure checked
Old Dec 18, 2011 | 01:42 PM
GOAT35's Avatar
Yeah I have a beater honda that just started having a fuel problem as well! I buy good gas from chevron..I don't know why i'm so unlucky.
1200 wow that stupid cheap makes me want to keep my car even longer shes at 157k.
I have no bolt ons whatsoever but correct me if I'm wrong the walbro pumps nearly 3X the amount of fuel as the OEM pump I don't know if that would be a good thing. I found an airtex pump but haven't found a solid review about it yet.
Let me know if I should get the walbro or the airtex.
When i find out what pump to by ill get the guys there to check the pressure for me.
Old Dec 18, 2011 | 08:28 PM
GOAT35's Avatar
Just said F-everything grabbed my key went to autozone and did that shyt!!! So proud of myself right now finished the pump install in under and hour and 2 beers!
Old Dec 18, 2011 | 08:33 PM
butkiss1's Avatar
How's she run?
Old Dec 19, 2011 | 12:54 AM
GOAT35's Avatar
Can't believe I didn't notice how bad it was b4 now she's running better than ever! Neck breaking acceleration has returned and never been so happy!
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
