Buyin 2003 G35. Problems?
Rating: Thread Rating: 3 votes, 5.00 average.
Old 07-19-2012, 02:33 PM
Matt W's Avatar
Originally Posted by AARONHL
Yea I have the leaking into the spark plug hole..I think you've covered all of it, you'll never know what problems will arise until you use it.
Thanks again, I will be looking for all of these issues today when I go to luck and hopefully may help to bring the price down a little bit. Are these what I should be looking for/listening for to identify potential issues?
Engine Valve Cover Leak - Oil around spark plugs / ignition coils - maybe oil burning smell.
Front Compression Rods/Bushings - Clunking/squeaking sound from front suspension going over bumps.
Wheel Bearings - Listening for whining noise when reach speeds near 40mph, can indicate bad wheel bearings. Grab top of tire and shake in and out with force, if I hear clicking or clunking, might have bad wheel bearing.
Bose Audio System - Make sure system is working, not much else you can do because it will probably go out eventually and plan to replace with double din pioneer or kenwood anyway.
Sway/Stabilizer Bar Bushings - Visual Inspection, look for tears..etc.. This is a cheap and easy DIY fix anyway so not a big deal
Also I heard the NISMO bushings are alot better/reliable - http://www.mynismo.com/products/Default.asp?id=5348 - I can get all 22 bushings for $400 are these good and is that a good price?
I also have a question regarding this picture
Can anyone point out to me where the Control Arm Bearing, Front Compression Rod/Bushing, and Sway Bar/Bar Bushings are at? Thanks!
R350k5
10-01-2015 08:41 PM
andyg35c1
08-29-2015 03:37 PM
chinee
08-08-2015 10:11 AM
Terry_G35
08-04-2015 02:38 PM
realtalk21
07-20-2015 09:07 AM
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Buyin 2003 G35. Problems?
