How To Wire in AUTO FOLD feature for your JDM Folding Mirrors
Old Feb 24, 2013 | 09:03 PM
  #31
TunerMax's Avatar
G35
You will need to run 2 wires through the JDM motor, and use your USDM mirror (the physical mirror) because it has the heater element on it.
The wiring is there on the 'car side' already for the heated mirror, but it won't be inside the JDM mirrors.
If you don't want to take the mirrors apart (makes it a much bigger job) then you will lose heated mirrors.
Old Feb 24, 2013 | 09:46 PM
  #32
MPG35fiend's Avatar
Thanks man... I really appreciate all of your help!!!
Old Feb 25, 2013 | 06:54 PM
  #33
allanmaxt's Avatar
Where can I get a set of these from ?
Old Feb 26, 2013 | 10:33 AM
  #34
TunerMax's Avatar
G35
Multi-Bump for the new thread with straight up answers
https://g35driver.com/forums/g35-sed...ml#post6702773
Old Jun 6, 2013 | 07:51 AM
  #35
neo_anderson302's Avatar
Old Mar 28, 2015 | 08:23 AM
  #36
rase77's Avatar
hi,
thanks for your guide.
just wonder, why i got spark/wire burning when connect +12v to pin #85.
did i do any mistake?
my wiring as per below; (following guide from you)
RELAY #1 (FOLD OUT)
85 - Trigger from TIMER FOLD OUT relay [BCM Term 23 (Unlock)] = +12V?
86 - Ground = Body ground/Batt +?
30 - Out to Motor (Fold Out Wire) = wired to motor +
87 - Positive power from BCM = constant +12V from Batt
87a - Ground = Body ground/Batt - ?
RELAY #2 (FOLD IN)
85 - Trigger from TIMER FOLD IN relay [BCM Term 30 (Lock)] = +12V?
86 - Ground = Body ground/Batt -?
30 - Out to Motor (Fold In Wire) = wired to motor -
* this is for other JDM car.
Thanks in advance.
Old Jul 16, 2015 | 05:10 AM
  #37
.cakestar's Avatar
Had him make me a custom set of modules. FS now
https://g35driver.com/forums/audio-v...ml#post7008972
Old Jul 21, 2015 | 08:18 AM
  #38
Mr. Brooks's Avatar
Here's a dumb question. Can we use are existing power mirrors or do we need to purchase a set of folding mirrors as well.
Old Jul 21, 2015 | 07:19 PM
  #39
TunerMax's Avatar
G35
USDM mirrors are power adjustable, not power folding. There is no motor in them. You will need the JDM folding mirrors for the internal folding motor. No motor = no auto fold
Old Dec 12, 2017 | 01:12 AM
  #40
ojra89's Avatar
M37
Hi all, I was thinking of doing this for my M37 with built-in power folding mirrors and came across this post which was awesome.
My concern was that the mirrors would fold when I lock the car? Is this not the case? Are the unlock/lock wires from the BCM only for the key transponder, but not internal locking/unlocking?
Thanks again!
Old Dec 12, 2017 | 06:42 AM
  #41
.cakestar's Avatar
yeah this guide would only respond to the key fob lock. i have this entire thing he built me but never used if you want it i can sell it to ya
Old May 22, 2023 | 06:08 AM
  #42
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
The 1st 2 links in Supplies needed no longer work anymore. Tuner Max, are you in the Facebook group chat called V35 Sedan Drivers?
MotoCARR
Mar 20, 2026 08:05 PM
Garnet Canuck
14
May 3, 2016 07:59 PM
nar93da
Aug 3, 2010 03:57 AM
KulG35
V36 DIY
13
Feb 11, 2009 03:39 PM
