how bad is it to...
Old Jan 16, 2005 | 01:29 AM
antho2006's Avatar
how bad is it to...
"re-ignite" the engine when it is already running. Not sure what the correct terminology is, but last night I forgot that the engine was already on, and I turned the key again. How bad is this for the car? It has 300 miles.
Old Jan 16, 2005 | 02:27 AM
G35keg's Avatar
Bad news bro, your engine is toast
hehe just kidding.... your fine... wouldn't worry about it.. I think its happen to everyone at least once...
Old Jan 16, 2005 | 02:57 AM
mark986's Avatar
I've noticed with some domestic cars they will not make that annoying sound when you turn the key when the car is already on. Not sure if this is some sort of safety feature, but why don't our G's have it?
Hopefully some of you have noticed the same thing.
Old Jan 16, 2005 | 05:30 AM
subrobo's Avatar
Yup yup yup!!! toasted~
If you try more then once...you will see a big black cloud when you open your hood then you can start cooking eggs on your engine.
Old Jan 16, 2005 | 10:18 AM
KPierson's Avatar
That annoying 'noise' is your starter engaging and trying to turn your flywheel. Since the flywheel is moving already the sprocket on the starter grinds to the flywheel. Other then that I don't think it will hurt anything.
Old Jan 16, 2005 | 12:27 PM
antho2006's Avatar
hahaha, ok...so i guess it isn't too bad. thanks
Old Jan 16, 2005 | 04:00 PM
Msedanman's Avatar
O.F. Administrator
Don't let 'em fool you bro. It's not toast at all........
But it will cost about $3k to fix.
J/k bro. Don't worry about it,. The worst that could happen is you had to replace the ring gear and/or the starter, but only if you did that every day for a month.
The occasional 'BooBoo' like that won't do anything.
No worries.
See, I just saved you $3k.
Old Jan 16, 2005 | 11:33 PM
Shoof's Avatar
No big deal as long as you don't do it too often, you don't want to burn your starter!
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
