Shaking when Applying Brakes
Old Dec 12, 2012 | 04:59 PM
jeffvq35's Avatar
Sup guys Need a Little help here i changed both Rotor's and Pads all the way around but hwne driving at high speed 60-70 i apply brakes i still feel the shaking not sure if its control arms tie rods etc maybe you guys can help thanks
Old Dec 12, 2012 | 05:06 PM
Shanes_G's Avatar
Make sure your lugs are all tight
Old Dec 12, 2012 | 05:23 PM
That's G's Avatar
^ This or one of your tire may be out of balance.
Old Dec 12, 2012 | 05:50 PM
TurTLe*'s Avatar
after you confirm your lugs nuts are tight, CONFIRM the bolts that hold the brake caliper are on there TIGHT.
I'm sure its one of those.
Old Dec 12, 2012 | 08:23 PM
sh0rtys463's Avatar
I'm assuming you had a shake before that is why you chose to change rotors and pads correct? Im gonna say its bushings (control arms and/or compression rod)
Old Dec 13, 2012 | 03:06 PM
VMRWheels's Avatar
^Good assessment. Could be a number of things. I don't think it'll be loose lugnuts because that would be apparent even when he's not on the brakes. My guess is a bushing as well.
Old Dec 14, 2012 | 08:46 AM
g35x300zx's Avatar
Maybe you got the brakes hot and warped the rotors they need to be broken in by not getting hot for the first couple hundred miles just a thought
Old Dec 14, 2012 | 10:25 AM
KNS Brakes's Avatar
Depends on the pads you put on you could have heated them up to much and now have pad deposits on your rotors which is giving you the judder sensation. What you can do is clean the rotors with emory cloth and some elbow grease, scuff up the pads a bit, install again, rebed the pads and be sure not to drag the brakes.
What kind of pads did you get?
-Nick
Old Dec 15, 2012 | 01:13 PM
Captain Kirk's Avatar
Check your calipers too if one of them is bad it can make your car shake while braking. My last car (97 t-bird) had the same problem. I changed the rotors and pads but not the calipers. If your car also pulls to a certain side even slightly while applying hard brakes I can almost guarantee you it's the caliper(s)
Old Dec 16, 2012 | 11:14 PM
JayVQ's Avatar
+1 on the bushings. My compression rod bushings are shot and get a lot of shaking when I brake.
Old Dec 17, 2012 | 06:05 PM
B T's Avatar
B T
did you have uneven wear on your pads? could also be a stuck caliper causing warping in your rotors from excessive heat.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
