Windshield wiper is hitting the trim when activated
Old Apr 19, 2013 | 06:39 PM
DVG's Avatar
DVG
Makes a very audible banging sound every time the wiper goes. Anybody know why this may be? I took off the nuts to paint them over the summer. Maybe I moved the wiper up or something so now its offset?
Any ideas/similar experiences?
Old Apr 19, 2013 | 06:56 PM
Frankieg35's Avatar
Is it hitting somewhere?? Make sure the nuts are torqued down enough..
Old Apr 19, 2013 | 06:57 PM
DVG's Avatar
DVG
Its hitting the trim on the edge of the windshield, some scratches are visible.
Ill check that when I get home, thanks.
Old Apr 19, 2013 | 07:00 PM
neo_anderson302's Avatar
adjust the height of it.
Old Apr 19, 2013 | 07:29 PM
saywat?'s Avatar
id remove the wiper, make sure its in the off position and put the wiper back on aligned with the other side. then adjust accordingly if needed.
Old Apr 20, 2013 | 05:34 AM
srv2nv's Avatar
G35 Sport
Is it every time or just when its on the highest setting?
Old Apr 20, 2013 | 08:14 AM
DVG's Avatar
DVG
Pretty much always, except when the rain is really heavy because that seems to slow the wipers down.
Old Apr 20, 2013 | 01:07 PM
bigc's Avatar
Wings Nation
loosen the bolt, adjust the wiper so it can't swing that far over, then re-tighten the bolt. it was probably just misaligned after you painted the bolts last summer.
Old Apr 21, 2013 | 02:36 AM
bythabay's Avatar
Check how much the wiper arms move when the wiper motor is off. If there is excessive play and both arms move the same amount you will need to replace the wiper linkage.
Old Apr 23, 2013 | 04:13 PM
si_driver's Avatar
There are these little plastic caps on the arms of the wiper assembly, they wear out... You have to replace one or possible two of the long straight metal pieces which come with brand those caps.. It's called the assembly link arm.
You may need only one or both.
parts needed:
(Long one): INF 28842-AL500 $12.04
(Short one): INF 28841-AL500 $11.44
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
