Tiptronic (MM): Not working. Suggestions?
Old Dec 17, 2020 | 05:09 PM
  #31
oscarzed666's Avatar
G37 Journey
Angry HELP!!! Manual mode in AUTO G37 Not working!
Originally Posted by Scorpi0
Been having this issue for the past few days and noticed a pattern in its behavior.
When my car has been sitting for a whole day and the transmission and engine are cool, if I start it up and try to put it in manumatic mode in under approximately one minute, the manumatic wont engage. And since it fails to engage, it is locked out by the ECU and will be inoperative until I shut the car off and back on again, resetting the system.
This only happens when when my engine hasnt warmed up yet. If I start my car and drive/let my engine warm up before I put it in manumatic, it works fine.
I’m gonna do some more experimenting and maybe I can figure something out.
HAS ANYONE FIGURED THIS OUT?? I have the same issue for my 2008 G37 Coupe. The MM used to work a lot, and as time went on its worked less and less and now not at all. Any time I try to engage MM, it kicks me back into drive. DS works just fine, but only if I can get it to engage. Sometimes it doesnt engage at all. Brought it to Infiniti, they switched out the shifting assembly and that did not do anything, the same problem resurfaced. I AM GETTING MY CAR TUNED IN FEB AND WHAT TO FIX THIS BEFORE. Otherwise Im just gonna sell it. Ill get nickle and dimed to death with diagnostics
Old Dec 17, 2020 | 05:10 PM
  #32
G37 Journey
did you ever figure this out? The shifting assembly replacement didn't do anything for my 08' g37 coupe either
Old Dec 17, 2020 | 11:42 PM
  #33
Scorpi0's Avatar
I had my transmission rebuilt and that didnt fix the issue either. I know all my switches in the shifter assembly work, so thats not the issue.
Ive heard a few people on here say that the manumatic sends a signal to the cluster before going to the ECU. A bad cluster might be the cause of manumatic not working. I might switch mine out one of these days just to try it out.
Old Dec 18, 2020 | 12:54 AM
  #34
G37 Journey
Potential fix
I contacted a few places about the gauge cluster and here’s what I found:
-Some local shops won’t do the cluster replacement since you need a certain tool to reprogram the mileage
-some people did this and it didn’t even fix the problem
-Infiniti charges $1700 for the cluster replacement and labor
I called a shop by the name of The Auto Service in Santa Ana. The guy I spoke new worked for Nissan/dotson for 40+ years. He knew a lot about the issue we are speaking about and is providing a fix on Monday, he says he’s is fairly certain he knows what the issue will be and can fix it. Just to remind you guys, I already did the shifting assembly replacement and that didn’t work either. I’m getting my car tuned in Feb at specialty Z, therefore I need my shifting!!!
Old Dec 18, 2020 | 02:39 AM
  #35
Scorpi0's Avatar
Definitely update us if he does figure out whats wrong with it.
Old Mar 6, 2021 | 05:15 PM
  #36
Dave Carella's Avatar
g35x
The signal is the dash cluster if you move the tilt column
in and out does it change ?
Old Jul 15, 2021 | 01:35 PM
  #37
4mermarine's Avatar
This little tip right here saved me hours of possible troubleshooting. I just got my instrument cluster board replaced and since reinstalling my Tiptronic (sport shift or whatever) would not work at all. I could put the shifter into that mode but it never when to manual. I adjusted my tilt column in and out, up and down, then my manual mode started working all the sudden. Crazy fix, but it worked for me. Thanks Dave!
Old Jul 16, 2021 | 09:41 AM
  #38
4mermarine's Avatar
Spoke too soon (karma). Sport shift is intermittent. Works every other drive. The saga continues. Ugh
Old Jul 17, 2021 | 11:14 AM
  #39
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you need to clean the manumatic contacts on the shifter. Use a plastic safe electrical contact cleaner.
Old Jul 17, 2021 | 06:43 PM
  #40
g35x
Seems like it’s in the cluster that’s why I said to move column around
Seems like it is in the cluster,that’s why I said to move column around I move my tilt and the e brake light goes on and off
Old Jul 27, 2021 | 01:18 AM
  #41
Scorpi0's Avatar
I have noticed my manumatic will always work for a few minutes on a cold morning. Then it will slowly start lagging the shifts and eventually quit completely.
I actually want to remove my gauge cluster completely and try the manumatic on a cold morning just to see if the cluster has any role in allowing the manumatic to work or not.
Old Jul 27, 2021 | 01:20 AM
  #42
Scorpi0's Avatar
I think every other issue about the G35 has been figured out except for this damn manumatic issue. Nobody has been able to do it.
Old Jul 27, 2021 | 03:04 AM
  #43
jbarnett250's Avatar
I drove around without my cluster installed a few weeks ago while I had it apart to fix something. The car would occasionally go into limp mode. I don’t recall if I tried manual mode or not. Let us know if you can drive no problem without the cluster installed. It had never gone into limp mode before or since so I’m confident disconnecting the cluster had something to do with it.
Old Jul 29, 2021 | 09:37 AM
  #44
4mermarine's Avatar
The only real change for me was the replacement of the cluster board. Since that my manumatic has worked intermittently. Have to assume it's something related but no clue where to go from here. Has always worked fine before the cluster board swap. I'll probably reseat the cluster connections and see if that helps.
Old Jul 29, 2021 | 10:43 AM
  #45
Scorpi0's Avatar
I wonder if anyone is selling a cluster off of their car which had a fully functioning manumatic. We can get it and test it out on our cars to see if it makes a difference.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
