5AT sometimes SUCKS
Old Feb 5, 2005 | 09:40 PM
iafzal's Avatar
5AT sometimes SUCKS
I have this issue that I think many of you might have experienced too.
The other day cruising around 20-30mph I punched the pedal to accelerate so I can catch up a light that was about change. The rpm in a flash rose to 4000rpm without any torque prdouced just like you would if the car is in neutral. I was a little surprised so I ended up taking my foot off the pedal and then slowly accelerate.
A number of times I have similar experiece... if you try to accelrate to fast torque converter really does not engage unless you do it slowly. I heard that this is by design but I wish that there is a way to be able to disable or reduce the lag. I love the 5AT but it SUCKS in this regards.
Old Feb 5, 2005 | 10:18 PM
G4me's Avatar
Hmmmm.. whenever I do that.. the G hauls butt.
Old Feb 5, 2005 | 10:20 PM
GeoBau's Avatar
Cactus Hugging Admin
...never experienced that. That would annoy the crap out of me.
G
Old Feb 5, 2005 | 10:37 PM
PagsTx's Avatar
I have noticed when you go to WOT while cruising that the RPM's will rise for a short period of time without a shift then the tranny downshifts and it's like a rocketship. However, the 1 or 2 second lag is noticeable and mildly annoying particularly when merging.
Don't know if that is what you experienced or not.
Pags
Old Feb 5, 2005 | 11:06 PM
tkman00's Avatar
yeah i experience it all the time
Old Feb 5, 2005 | 11:12 PM
shooter's Avatar
It's not the critic......
when is the last time you did a 12 hour ECU reset?
Old Feb 5, 2005 | 11:27 PM
G35sedanman's Avatar
I have experienced a slight lag on occassion, but, she usually launches like a bullet...a silver bullet as a matter of fact. And, I call my G SILVER BULLET!
Old Feb 6, 2005 | 02:11 AM
Hyde's Avatar
it always happen
Old Feb 6, 2005 | 01:31 PM
iafzal's Avatar
Yes guys I am in short talking about the lag. I have noticed it usually around a second or so when I try WOT. Although that time it was maybe 2-3 seconds. You know that much time is an eternity if you are trying to merge or make a quick pass. I just leaves a bad taste in your mouth as otherwise that car acceleration is awsome once it kicks in.
Another time I was trying to impress someone with how fast G is so on and it happened when I tried to qucikly acc. by punching the gas and G revs like crazy for a about 2 seconds and don't go anywhere. I was embarrased instead
Old Feb 6, 2005 | 03:03 PM
calejohnson's Avatar
I noticed this lag but don't notice it much now. I've changed the way I apply pressure to the throttle. I don't know if it is in the ATs algorithm, but the car seems to respond to stabbing at the throttle with a hesitation. On the other hand, by gradually increasing pressure on the throttle in a deliberate fashion gets the car underway in a hurry. It feels as though I don't need to floor it to get WOT.
Remember, this car it 'drive by wire" and has a software link between the accelerator pedal and the throttle body. It's possible that Nissan put in a "safety" to reduce the potential for unintentional acceleration. Of course, it could also be a glitch.
Either way, I found that adapting to the nature of the system saves me from going crazy for 2-3 seconds.
Old Feb 6, 2005 | 04:00 PM
jadaway2's Avatar
The lag does get annoying. i get it in both automatic and manumatic. From what I hear the grounding kit is supposed to fix that.
Anybody out there with the 10 wire grounding kit think that the lag goes away with the kit?
Old Feb 6, 2005 | 04:24 PM
PagsTx's Avatar
Hmm. Will have to try and apply the leadfoot a little slower and see how that works.
Pags
Old Feb 6, 2005 | 04:59 PM
themax98's Avatar
my 98 maxima does that also. it started doing it at about 90k miles on the tranny. Just as described by everyone else. maybe its a nissan thing. as per a saftey feature i know my tranny will lock in third if there is excessive tire spin to prevent damage to the tranny. but if ur cruizin and trying to merge onto a hwy. having that lag is not good. other than this occasional prob ive changed the tranny fluid three times already and it doesnt slip.
Old Feb 6, 2005 | 05:15 PM
cato's Avatar
SouthernComfort Moderator
No lag on mine, although I really never just punch it to WOT. By applying
steadly increasing throttle, it takes off like a rocket ship.
Old Feb 6, 2005 | 06:37 PM
jimNC's Avatar
This lag has happened to me a few times as well. I reject it is occurring as the result of a safety feature, because not getting the response you would expect when you push the peddle hard can be quite dangerous in tight merge conditions. There are other instances where the reverse would be true, but in my estimation it is more dangerous to make it so that the behavior is not consistent.
