Power steering problems after swanging
Old Apr 20, 2015 | 11:03 PM
Joe222's Avatar
I did a donut and it would feel alittle stiff after but I didn't think much of it. I did it again a week later and it got really a stiff and wouldn't go away. It made a whining noise when if turn it almost all the way then grind. But that only happens when going slow speeds like under 10. I changed the power steering fluid and it still didn't work. About a month went buy and it felt the same but I got used it it. I swung it again and I heard like a electronical burst noise lw like a small turbo idk how to explain it lol. I'm thinking a fried steering pump or p/s gearbox?? Any help?
Old Apr 21, 2015 | 08:47 AM
Mustang5L5's Avatar
Originally Posted by Joe222
Any help?
Stop doing donuts??
You probably had at full lock and the donut stressed the steering rack or pump beyond what it was designed for. But it's hard for us to diagnose the issue from here. You are going to need to get it checked out. Aftermarket rack about $300ish. Aftermarket pump about $200ish. Dealer prices for OEM stuff will be WAY more. Then factor in shop time and part markup (10-20%) if you have a mechanic do this for you. Not a cheap fix.
You probably want to take care of it soon before you have a serious failure at a time you really don't want your steering to quit.
Old Apr 21, 2015 | 12:22 PM
Joe222's Avatar
Thanks man I'll look into it
Old Apr 21, 2015 | 03:26 PM
joedaddy1's Avatar
labor $500+ btw...
Old May 9, 2015 | 12:51 PM
Joe222's Avatar
I fixed the power steering pump and it's all good now. 👌
Old Jan 3, 2021 | 06:45 PM
Michael-'s Avatar
2006 G35 Coupe 5AT, Motordyne Shockwave TDX2
What did you do lol I swang mine now it’s the same issue you got
Old Jan 3, 2021 | 08:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Anytime it's making noise like that and has full fluid it's the pump itself that's failed.
array35
16
Oct 31, 2023 03:31 PM
Coupe_35
Sep 6, 2020 09:10 AM
Fire0nic3
Dec 11, 2018 12:26 PM
aRT13
Dec 27, 2011 07:42 PM
cHink
May 11, 2011 12:43 PM
