Steering Radio Controls
Old Apr 29, 2015 | 09:29 AM
Tylko Kazik's Avatar
Hello once again! I have read that its common for the steering radio controls to stop working. I have noticed my car doing the same thing, the switches will only work if the wheel is at certain position . From what i understand its not worth just replacing it because same thing will happen. How did everyone go about this problem ? I do use the controls a lot in my previous cars so i would like to solve this problem .thanks
Old Apr 29, 2015 | 12:39 PM
Deepdiver's Avatar
it sounds like the clock spring in your steering column is going out. Thats the part that maintains an electrical connection but still allows you to rotate the steering wheel.
Old Apr 30, 2015 | 08:41 AM
Mustang5L5's Avatar
Yup, sounds like clockspring issues
Old Apr 30, 2015 | 09:45 AM
is it worth changing or will it go bad soon anyways ? I know its the clock spring, i just heard they keep going out .
Old Apr 30, 2015 | 10:08 AM
Mustang5L5's Avatar
I've seen failures on the forum, but not that frequently. I'm still on my original at 155K
Old Apr 30, 2015 | 12:10 PM
Deepdiver's Avatar
replace it based on: 1) How important is the feature to you? 2) How long do you plan on keeping the car? 3) Cost. It is a wearable item, but not something that goes out frequently.
Old May 3, 2015 | 05:03 PM
ok guy i will look into how much it is and how bad of a job it is then , i do like the steering wheel controls
Old May 9, 2015 | 11:28 PM
boatloader's Avatar
Please do let us know how it turned out. I just bought an 05 g35x with 130k miles and i totally have this problem.
Old May 10, 2015 | 03:30 PM
If i do decide to do it i will definitely report back but i dont plan on doing it soon, just did both bearings, front brakes , trans and dif fluid change so for now im freezing my spending on the car .
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
zcherub
Sep 10, 2015 12:03 PM
Kicknshift
Sep 3, 2015 09:35 AM
pasjr1972
Sep 1, 2015 10:17 PM
