Is this better than HR Y-pipe?
Old May 13, 2015 | 02:34 PM
thaBrad's Avatar
Seen this on Craigslist. I'm searching for HR Y-pipe for my Sedan. Will this do any better than my OEM Sedan Y-pipe?
Old May 13, 2015 | 02:39 PM
gary c's Avatar
Just don't buy eBay trash!
Most anything is better than the OE y-pipe, this one will do fine! Better yet, get a true dual system for the best results!
Gary
Old May 14, 2015 | 11:13 PM
The Fixer's Avatar
Looks good, but if your G is AWD that probably won't clear the transfer case.
Old May 15, 2015 | 02:49 PM
Mustang5L5's Avatar
Would help you know year and model of what you are putting it on, and what that pipe is off.
Old May 15, 2015 | 05:31 PM
TurTLe*'s Avatar
that pipe is a ebay pipe. i think its called m2 or megan racing or manzo. All the same people just diffrent names.
Old May 16, 2015 | 09:35 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Doesn't even look symmetrical. I'd have to see the inside of where the pipes join, because if they just mashed them together instead of cutting a nice angle and merging properly, they made a major chokepoint in the exhaust.
Old May 20, 2015 | 01:03 PM
Jeff92se's Avatar
Red Card Crew
Only thing better than the HR Y is the Motordyne Y. Although my Borla cat back with resonated Y was great
Old May 20, 2015 | 01:18 PM
Patrick Bovee's Avatar
When you buy a full borla catback does it come with a Y pipe or is that sold separately from the exhaust because I get a little rasp would a Motordyne Y pipe help?
Old May 20, 2015 | 02:09 PM
Jeff92se's Avatar
Red Card Crew
It does but both pipes dump into a 2 in 2 out borla muffler. Not really a Y. So I chopped that off and put a Magnaflow resonated X pipe. Less rasp and a little more torque down low
Old May 20, 2015 | 03:45 PM
OK well I'm def. going to do this because my rasp is a little annoying, can it also be the ART pipes are to strong for the Borla Catback?
Old May 20, 2015 | 04:37 PM
Jeff92se's Avatar
Red Card Crew
Might be to big of an OD
Old May 20, 2015 | 04:39 PM
So the outer diameter may be to big? On which the Art pipe or the pipe connecting to them from the exhaust?
Danielek
May 1, 2022 01:28 PM
Video Share
Jan 31, 2017 04:00 PM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
