Compression Rod Removal
Received 2,458 Likes
on
Coupe 6MT Premium RAS
jstine8585 (06-11-2018)
Thanks all! I did manage to get it to turn after soaking the heck out of it with PB Blaster + being patient + breaker bar. Thought that was the end of it.....but Noooooo. The compression rod bushing had seized to the stud that's welded to the frame. And when I say seized, I mean it became one with the stud. Had to cut and cut and cut and cut it. Finally, after basically removing most of the metal pushing, I hammered the crap out of it, and it finally moved enough to remove the whole thing. SUCCESS!!! And then I realized that I damaged the threads on the stud. Great. It looks like I can rethread it with a tap and die set (14mm x 1.50). Any thoughts on that?
I drove ttrank's car solo
Received 1,486 Likes
on
Got it Urban, you'd have to buy their $85 kit to get the 14-1.5.
https://www.harborfreight.com/45-pc-...set-60676.html
None of the cheaper kits have that large of a size.
Blue Dream (06-12-2018)
Blue Dream (06-25-2018)
on
on
Blue Dream (06-26-2018)
jstine8585 (07-09-2018)
