Codes P0300 and P0302
Old Feb 25, 2019 | 09:35 PM
  #46
Zeek2127's Avatar
G35
Well it was the top item they found wrong while doing the diagnostic so it's something that needs to be done before the car can be driven. Otherwise every time you touch the steering wheel it will kill the engine.
Okay thank you so much, if that doesn’t work do you know what the next thing to do would be?
Old Jun 24, 2023 | 12:35 PM
  #47
Banjor1's Avatar
Cruise control 3.5 ltr
P
P0021 engine code still showing I have replaced coil packs spark plugs camshaft sensors throttle body cleaned MAF sensor and car is still billowing smoke and rough idle still giving me a p0300 code any advice how I can tell if my vtc solenoid is stuck or malfunctioning
Old Jun 24, 2023 | 01:00 PM
  #48
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What did the spark plugs look like? P0021 will not cause billowing smoke.
P0021 just means theres a difference in the cam angle the ECM is demanding vs. what it's actually measuring, typical first troubleshoot would be to pull and inspect the cam solenoid for debris stuck in it's screen, or just replacing the solenoid. No reason to change the cam sensors but if you do it MUST be with either the OEM Nissan ones or Hitachi (Hitachi was the OEM manufacturer).
P0300 random misfire could be a lot of things, did all the old spark plugs look good or was there one or more that looked significantly crapped out? Are you 100% sure you got the coil pack harnesses installed in the correct order? It's easy to get them mixed up.
If you got the coil pack harnesses mixed up you can cause a P0021 because the engine keeps trying to stall.
P0021 can also be caused by a blown gallery gasket although it's less common on the DE engine in the V35 chassis. The HR engine in the V36 chassis was a lot more common. Typically it would throw both P0011 and P0021 though.
If you're billowing BLACK smoke that's rich combustion chamber conditions, maybe a stuck injector. If you're billowing BLUE smoke you need to do a compression test, might have blown the rings.
Are there any other codes you're throwing besides P0300 and P0021 ?
The Hawk22
Intake & Exhaust
Mar 24, 2022 08:16 AM
Au79
Apr 24, 2020 09:13 AM
Dlriousboy
May 24, 2017 11:06 PM
cfauvel
13
Oct 31, 2016 09:14 AM
Cesar023r
Jan 7, 2013 12:56 PM
