[CA] Cat replacement
Old Jun 3, 2020 | 01:47 AM
Gemichi's Avatar
Base model G35
Originally Posted by andrewl_v35
"All this means is that the DMV has chosen your vehicle to be inspected at a STAR certified smog station which is monitored closely by the BAR and must conform to high standards established by the Bureau of Automotive Repairs."
https://www.smogtips.com/star-smog-c...on-program.cfm
Basically, make/models that have higher frequency of failing smogs tests have to go to a 'star' smog test. Not to mention, the last 'star' smog I got was $75. Normal ones are about half that
To my knowledge, with the 'star' test means they put the car on a roller/dyno to test the tail pipe emissions, while normally they just test the tailpipe emissions and check for CEL codes at idle.
The joys of living in this state
ohh, so a normal smog check will not check on a dyno? If thats the case, I remember my parent's 90s corolla was put on a dyno for smog check years ago. I thought the car will blow up lol.
I hate this place even more when I found out I can't just simply import 25 year old cars and register it... ( tbh, I want something else other than a G, but G is the next alternative)
Old Jun 6, 2020 | 12:11 AM
858G's Avatar
sedan
Apparently the Kinetix HFC have passed the 'sniffer' exhaust testing in CA.
G35s don't get sniffer tested in California. Smog check is done through OBD2 port only. They just need to see all monitors ready, so your O2 sensors have to be happy (or tricked).
Only cars from 1976 to 2000 go on rollers and get sniffer test.
Old Jun 6, 2020 | 08:26 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
My first Maxima had cat issues, very common on those cars, especially the early VQ35s. Mine was the 92nd one built for '02 (June '01 build date) and it used a quart every 1500-1800 miles. Would occasionally get a P0420/0430 but the biggest issue was my car wasn't running as strong as it used to. Got on the freeway behind a Grand Am GT (185 hp IIRC) and I barely got around it. Found some used cats, swapped them in and timed 45-85 run showed a full three second improvement. You could see the original cats had some clogged up cells. So it isn't just not passing smog, bad cats can hurt performance too.
Old Jun 8, 2020 | 05:29 PM
858G's Avatar
sedan
Regular (non-star) will still put a 76-00 car on rollers for the 15 amd 25 mph tests.
Again, G35's do not go on rollers in California.
bongoz
Jul 22, 2016 12:09 AM
mikeG35S
V36 Engine, Exhaust, Drivetrain & FI
Jul 13, 2015 01:43 PM
harleymd
Jun 1, 2015 08:34 PM
thecos54
Jun 19, 2009 09:14 PM
