2005 Sedan SLIP VDC issue
Old Oct 5, 2020 | 09:59 PM
ruby2ny's Avatar
04.5 coupe 6 mt, 05 sedan 6 mt
I was driving home today and all of a sudden my car stopped accelerating in gear, when I shifted to neutral I could still rev the car up. I tried limping it home by revving it up and dropping the clutch since I was only a mile away, as soon as the clutch engaged it wouldn't accelerate. The dash soon turned off completely, it flickered a bit then completely shut off. I pulled over and turned it off, tried to start it again and it wouldn't crank no clicks or anything, headlights were able to turn on but the windows would not operate. Decided to wait a bit and call my buddy who has a jump pack. Before connecting it I tried cranking it one last time and it gave me a really weak crank before it starting clicking. We connected the jump pack and it started right up and drove fine, the slip and vds light turned off. Any idea what this could be? I had an automatic coupe before and this issue was caused by the cam position sensor, soon as that was replaced everything was fine. Did a bit of reading before posting this and it seems like it could be a throttle position what do you guys think?
Old Oct 10, 2020 | 07:40 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Dash flicker and stuff like that is definitely not a CKP/CMP sensor issue, you have a loose/corroded/broken wire somewhere.
Old Oct 11, 2020 | 04:08 PM
ruby2ny's Avatar
Do you think it's a battery issue? It didn't want to crank until it was connected to a jump pack, but it's been almost a week since the incident and it cranks right up every time.
Old Oct 12, 2020 | 07:30 PM
ruby2ny's Avatar
Tested out my alternator further and it appears to be fine for now, maybe when it's hot it starts acting up? Or is it possible theres a short in the battery?
Old Nov 3, 2020 | 07:06 PM
ruby2ny's Avatar
going to swap out fuel pump to see if it fixes issues, slip vcds light was tied to wheel speed sensor
Old Nov 13, 2020 | 02:00 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Don't throw parts at it, check all your grounds first.
Old Nov 17, 2020 | 12:12 PM
ruby2ny's Avatar
grounds are good, went through and redid some, the one in the rear that mounts to the exhaust was the only "issue" still same thing happening
Old Nov 20, 2020 | 02:49 PM
Bsmith 04SDN's Avatar
G35x
Recently Had the same Issue
I had this issue a few months ago, after scouring the internet i found it to be my Crankshaft Position sensor. once replaced, i had no issues!
Old Nov 20, 2020 | 04:17 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Mine was the same, 05 also. It would shut down at 75mph in-rush hour traffic on freeway which is somewhat exciting. I went ahead and replaced both camshaft sensors and the crankshaft sensor with Hitachi I bought online. Think I gave about $150 for all three, problem solved.
Old Nov 20, 2020 | 07:04 PM
ruby2ny's Avatar
was yours throwing any codes?
Old Nov 20, 2020 | 07:28 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
If I remember correctly it was 0340. Also when mine had the slip, vdc light on the clockspring was beginning to malfunction.
Paul7296
V36 Engine, Exhaust, Drivetrain & FI
Aug 30, 2020 06:20 PM
ZippyDoozy
Feb 21, 2017 06:03 AM
Knasty29
Jul 7, 2016 04:28 PM
sk8boigage
Jul 8, 2012 12:36 AM
geesteezd
Aug 2, 2010 05:33 PM
