Reading the Transmission Temperature
Old Jul 27, 2021 | 06:45 PM
G35CO's Avatar
Is there a way to read the transmission temp for 03 sedan?
I have the Tourque Pro app and OBDLink MX adpater. There's no option to read the transmission temp.
I want to check the transmission oil level.
Old Jul 30, 2021 | 10:15 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Correct, there isn't a good way to read tranny temp, you will either need to cut in an aftermarket sending unit to the cooler feed line or temporarily put a sensor down the fill tube.
Checking oil level is easy, drive around for 15 minutes, put the car in park, leave the engine running, remove the fill tube cap (10mm bolt) and check the dipstick (wipe it clean 6-10 times before trying to get a reading, there will be a lot of fluid up in the well tube that needs to be wiped off).
EDIT: Make sure you're on a level surface when checking fluid level or it can appear to be WAY off.
iafzal
Mar 24, 2018 02:12 PM
FaureG35
Oct 3, 2011 06:45 PM
FiveSeven SS190
Jul 7, 2008 05:45 PM
belerin
Mar 31, 2004 06:13 PM
