350z de motor swap into g35
Old Oct 26, 2021 | 08:05 PM
Isaac875's Avatar
G35 6 speed
I am having problems with my swap. I put my 350z motor into my g35. They are both 03 de non revup. When we started the g35 it had p0300 random is fire code and it pop every 5 sec at idle. I didn’t not swap the wire harness because I was told everything was the same. I would appreciate help.
Old Oct 26, 2021 | 09:01 PM
srv2nv's Avatar
G35 Sport
My guess would be you have a couple of coil pack harnesses crossed.
Old Oct 26, 2021 | 10:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah I second the crossed coil packs, however if you had the flywheel removed and didn't properly align it's alignment pin up to the hole on the crankshaft then that may be the issue. The flywheel/flexplate can only install in ONE specific orientation for the engine to work.
There's a little dowel/divet mark on the flywheel that lines up with the empty hole on the crankshaft.
Old Oct 27, 2021 | 09:45 AM
Isaac875's Avatar
G35 6 speed
Thanks for the feedback I will try that out. All connectors should be the same correct?
Old Oct 27, 2021 | 09:48 AM
Isaac875's Avatar
G35 6 speed
Clutch
I had changed the clutch and fly wheel on the 350z 400 miles ago and it was running great. I don’t exactly think it’s the flywheel. Thank you.
Old Oct 30, 2021 | 06:29 PM
srv2nv's Avatar
G35 Sport
For the coil packs? Yes. And I forget what side, but I remember one side has 2 connections that are close together and easily mistaken for one another.
Old Oct 30, 2021 | 08:28 PM
cleric670's Avatar
BANNED!!!
Yes the harnesses are all the same but an easy identifier is one wire on each coil pack is a different COLOR (the one that goes back to the ECM). That color can be cross referenced against the wiring schematic in the FSM.
Cyl1 - yellow/red stripe
Cyl3 - blue/red stripe
Cyl5 - purple/white stripe
Cyl2 - green/red stripe
Cyl4 - grey
Cyl6 - grey/red stripe
Old Oct 31, 2021 | 01:17 AM
Scorpi0's Avatar
Its the driver’s side. The 2 aft coils.
Btlb89
Dec 16, 2022 01:16 PM
Gcouped05
Oct 18, 2012 01:06 PM
S2k.berto
Jun 9, 2011 01:52 AM
240kiid
May 16, 2010 02:21 PM
Hi-TechG35
Sep 12, 2006 05:32 PM
