Walbro 450 in sedan fuel pump assembly?
Old Jan 21, 2022 | 09:28 AM
craigslong's Avatar
Infiniti G35 Sedan 6.0 LS Swapped
Long time lurker, first time poster. I'm in the process of doing an LS swap on my '03 Sedan. I went to upgrade the fuel pump to a Walbro 450, and realized the fuel pump assembly is completely different than the G35 Coupes and 350zs. Is there any way to make the 450 pump fit in the sedan assembly? If not, can I run a coupe/350z assembly? I've tried searching high and low and can't seem to find an answer...
Old Jan 21, 2022 | 09:53 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Post a picture of it, I thought all the pump assemblies were functionally identical. I know when you purchase replacement stuff the sedan-specific bagged parts only have the pump/strainer but when ordered for the coupe it has the entire assembly.
Old Jan 21, 2022 | 10:03 AM
craigslong's Avatar
I'm not in the garage right now so this is a pic off google. This is what the stock sedan fuel pump assembly looks like. It is way different than the coupes/sedans.
Old Jan 21, 2022 | 10:26 AM
cleric670's Avatar
BANNED!!!
Huh yeah that's interesting, must be an early 2003 thing and I bet that car came with the non-tunable ECM as well.
I would just start taking it apart since I bet it has all the same components and it's probably just a chassis/housing design change they made. Or you could hit up a local pick-n-pull wrecking yard and pull the pump off a donor since the harness and feed line should be the same.
That housing is probably the reason why the sedan fuel pump kit from the dealership does NOT include the basket, because they're different looking. The fuel pump is the same regardless of year though.
Old Apr 5, 2022 | 07:05 PM
JaE35's Avatar
Moderator
G35 Sedan
Literally just ran into this same problem...i'm gonna see what I can do to try and make an 04 basket fit in the 03. Don't think this has ever been talked about
Old Apr 5, 2022 | 07:44 PM
craigslong's Avatar
i ended up using a coupe/350z fuel pump assembly.
Old Apr 6, 2022 | 10:44 AM
JaE35's Avatar
Moderator
G35 Sedan
Good to know..i was wondering if it fit okay
Old Apr 9, 2022 | 12:46 PM
cleric670's Avatar
BANNED!!!
I'm almost certain it's the same gas tank in the coupe, sedan, and the 350Z. I've compared them side-by-side and they look identical. Should be able to take any pump that came in those tanks and put it in yours.
Old May 25, 2023 | 06:39 PM
octaviorojas1's Avatar
2004 Infiniti G35 Sedan
Only real choice is the junkyard
I was struggling to find one for weeks until I realized my only option is the junkyard for replacements. Regarding upgrades I have no clue for the sedans.
Old May 26, 2023 | 11:30 AM
cleric670's Avatar
BANNED!!!
It's a different venturi valve hose and attachment to the pump on the sedan and coupe, you can pull the venturi hose off a coupe and put it in your sedan, then you can use the coupe pump.
You need the whole hose, it's attached to the bottom of the tank right by the saddle, it's INSIDE the tank so you need some long chem gloves to reach it if you have fuel in the tank. I would siphon it out into gas cans if the tank was full.
You could also pull one from a 350Z since I think they use the same style venturi as the coupe.
FreshTortilla
Mar 18, 2020 11:36 AM
QX1
Drivetrain
Mar 18, 2016 03:01 PM
Calipat916
Jan 14, 2016 02:43 PM
QX1
Dec 14, 2015 03:41 AM
Usman Ali
May 16, 2015 03:41 AM
