Accelleration from a standstill...
Old May 29, 2005 | 03:53 PM
azlane's Avatar
Test driving the 5AT Sedan and realizing the torque this engine puts out at low rpm made me think it would be able to turn the tires over pretty good with the VDC off. After buying the car and driving it a couple of weeks I have found out otherwise. Is my car sluggish or is everyone else experiencing this same thing? I'm guessing that if I were to turn the wheel and accellerate hard from a standstill it would break the tires loose, but I would have expected it in a straight line from a stop as well. Curious what others have found...
Old May 29, 2005 | 04:00 PM
zimbo's Avatar
Are you torque braking?
--Steve
Old May 29, 2005 | 04:28 PM
shodog's Avatar
On the 5at loaners I have had I noticed bit of lag when you punch it from the start. I think it's normal. if you wanted to roast the tires, you should have bought a 6MT. Those will spin the tires all the way until you worry about the replacement cost.
Old May 29, 2005 | 05:37 PM
azlane's Avatar
Not sure what you mean by torque braking. If you mean power braking where you hold your foot on the brake and rev the engine up against the brake, no I am not doing that - just punching the gas.
Old May 29, 2005 | 06:39 PM
skeleton_cru's Avatar
Sedan
Why would you want to spin the wheels?
Old May 29, 2005 | 07:40 PM
Texasscout's Avatar
Wink Auto abuse
Cru, you KNOW the answer to that question.
Old May 29, 2005 | 10:12 PM
Sedan
Is the answer "He used to drive a Camaro"???
Old May 30, 2005 | 12:30 AM
DaveB's Avatar
Yes, there is a 1st gear lag in the 5ATs and it is very deterimental to the overall performance of the car. It's clearly Nissan's way of keeping the G35 off the heals of the 350Z 5AT. The 350Z 5AT owners report absolutely no bog on launch and their average 60 foot times show it. They consistently get low 2.0s with just barely an 1800rpm powerbrake. The average 5AT G 60 foot is a mid 2.2. The 5AT 350 auto only makes about 7whp more the G sedan and weighs only 110lbs less. Those small difference aren't going to make a huge deal in the first 60'. That .2+ seconds 60 foot difference is costing the 5AT G a solid .3-.35 seconds in ET in the 1/4 mile.
I went to the track a few weeks ago for the first time in my G. I was launching at about 2000rpms. The car comes off the line hard for about 5 feet and then falls down and then takes off hard at 3500rpms. I got consistent low 2.2 60 foots on the 17s with barely a chirp. I'm considering on pumping up my 17s to 45psi in an effort to generate some wheelspin and basically jump over the 2000-3500rpm bog.
If people really want to go quicker in their G 5AT, they need to be focusing on that Nissan is doing to kill the performance on launch in 1st gear. It could mean the difference between running a 14.5 stock or a 14.2 (or better) stock.
Old May 30, 2005 | 12:39 AM
Texasscout's Avatar
Give that man a cigar!
Old May 30, 2005 | 01:15 AM
Sedan
YESSSSS!!!
Old May 30, 2005 | 01:43 AM
GEE PASTA's Avatar
Florida G35 Club
DaveB There was the same problem many years ago with the turbo 350 & 400 I wish I could remember the name of the part that caused the problem. The problem was under a hard lanch. the down shift or kick down" was over riding the pump and making way to much pressure in low gear. There was two things happening at the same time here. The pressure build up was way to high In low gear. I will figure out the part and PM you.
Old May 30, 2005 | 11:13 AM
Lamont Coleman's Avatar
Got an 05AT Ever figure out the what thepart was???Thanks
Old Jun 4, 2005 | 10:15 PM
QuadCam's Avatar
Is there anywhere that can modify the torque convertor for a slightly higher stall speed and greater torque multiplication?
That would solve the off idle bog.
3XaCharm
Aug 1, 2011 08:45 PM
Gee35init
Apr 1, 2011 11:58 AM
gottaGnow
V36 Brakes, Suspension, Wheels & Tires
16
Jan 8, 2010 01:15 PM
helloscotte
Aug 30, 2008 11:21 PM
