what type of gasoline to use?
Old Aug 9, 2005 | 05:26 PM
parsley's Avatar
Hi, I have a 2004 G35X that I bought a few months back. I've been getting premium gasoline into it and I am wondering if I can just use 87 or 87 octane rating instead of 93.
I don't actually remember what the manufacturer suggests at this time. My old car required premium gasoline, so, I was just using the same in this car too!! :
Thanks for your input!
Old Aug 9, 2005 | 05:40 PM
hilmar2k's Avatar
The minimum octane recommended is 91. You can run a lower grade, the engine will just "detune" itself a little to compensate, and therefore expect lesser performance. You also may want to run a couple of tanks of each and compare mileage, you may find the premium grade offers an increase in economy nearly equal to the premium in price you pay for it. Just a thought.
Old Aug 9, 2005 | 06:10 PM
kevink's Avatar
I personally have not really noticed any difference in performance and economy with 87 and 91 octane.
I will sometimes buy premium when the difference is less than the normal 20 cents/gallon.
Old Aug 9, 2005 | 07:56 PM
dfw1972's Avatar
http://www.washingtonpost.com/wp-dyn...080501595.html
Thoughts?
Old Aug 9, 2005 | 08:26 PM
kevink's Avatar
There is also mid grade. If you drive a car that requires 91, like I think the coupe does, maybe try 89 instead. Not quite the difference in price, but not the difference in octane too.
Old Aug 9, 2005 | 08:33 PM
nwG35Sedan's Avatar
Our pilot takes mid-grade, so I have no problems with using 91+... and I try to fill up at Chevron to take advantage of the techron.
Old Aug 9, 2005 | 09:19 PM
kswan53's Avatar
I also have a 2004 G35x. From the 2004 Owners Manual:
http://www.infiniti.com/m/pdf/manual...finiti-G35.pdf
"FUEL RECOMMENDATION
Sedan models
Use unleaded regular gasoline with an octane rating of at least 87 AKI (Anti-Knock Index) number (Research octane number 91).
For improved vehicle performance, INFINITI recommends the use of unleaded premium
gasoline with an octane rating of at least 91 AKI number (Research octane number 96)."
Old Aug 9, 2005 | 11:10 PM
mpgxsvcd's Avatar
Originally Posted by dfw1972
Telling someone to use lower octane gas than what is required by the manufacturer is reckless! If the manual says you must use 91 octane or higher then you better use 91 or higher especially if you get on the gas. If the manual says you can use 87 or higher but you might experience a performance hit at lower octanes then that is exactly what will happen(IE: G35). However, there are some cars(Honda Accord V6) that recommend 87 or higher but they will actually see a performance boost if you use 91 or 93. This is really the same as in the G35 except infiniti rates the cars horsepower on 91 octane where Honda choose to rate theirs at 87 octane for the Accord. They figure most Accord owners would rather save money on the gas than be able to brag that their car has 255 HP instead of only 240 HP.
Use exactly what the car’s manual recommends unless you are not concerned about power. In that case use the minimum required fuel. For the G35 that would be 87 Octane for the minimum and 91 for the rated Horsepower.
Old Aug 10, 2005 | 06:05 AM
FAST1's Avatar
One other possible disadvantage of lower octaine fuels is that some Gas companies put their best additives in their premium fuels. Shell is a good example. So I would do some research on the gas you use to ensure that you are not getting short changed with respect to detergents when you buy the lower octaine gas. .
Old Aug 12, 2005 | 01:53 AM
3199cc's Avatar
If I owned my G, like I did my CLK, I would put premium in every time. I'm leasing the car though, so I put in regular cause I know in the 3 years I have it there won't be any problems related to regular gas.
When you fill up at a gas station and see a person in a Cl55 or M3 using regular, you know their cars are leased as well as almost anyone who would buy the car outright would definitely know how to take care of it properly.
Old Aug 12, 2005 | 07:01 AM
skeleton_cru's Avatar
Sedan
This topic has been beaten to death, resurrected from the dead, and then bludgeoned to death again. I guess it's still not dead. Someone please kill it, dismember it and burn it to ashes!
Old Aug 12, 2005 | 09:39 AM
GeeWillikers's Avatar
Walking The Fine Line...
Originally Posted by skeleton_cru
This topic has been beaten to death!
And your point is?
Be back in a minute. I'm going to go post a "which is faster" thread followed by a "is this a good price" thread.
Old Aug 12, 2005 | 10:13 AM
Sedan
Originally Posted by GeeWillikers
And your point is?
Don't forget to start another CAI thread. There aren't nearly enough of those around.
Old Aug 12, 2005 | 12:36 PM
damonb10's Avatar
Yes, you can use lower grade. It's stated in your manual.
Old Aug 13, 2005 | 12:15 AM
G35Papa's Avatar
LOL
Return of the Living Dead part 482,901
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Kelvin Style006
May 23, 2016 03:47 AM
