Best and first mods to do to the sedan and why
ive had my G for about half a year now and havent really done anything to it. Im new to the import scene i just finally wanted a reliable nice looking car that i could run to 300k. Anyways, what are the first mods that should be done performance wise and why. Ive already got headers on the way, my friend works at a custom headers/exhaust shop and hes making me some for $200 and btw what is the grounding kit good for?
-Z-tube/K&N filter
-Motordyne Plenum spacer
-High flow cats
-Cat back exhaust
-Springs/shock or coilovers
-Sway bars
-Wheels/Tires
-TechnoSquare ECU reflash
I did not include brand names for most mods only because there are several good choices and you can research these for yourself. There is a lot of info already posted on these forums. Familiarize yourself with the search function and get to work.
-High flow cats
-Cat back exhaust
-Sway bars
-Wheels/Tires
Originally Posted by B&RCustoms
i was asking on a personal suggestion basis, kind of as in what mods people have started with and why they chose those
You need to at least say what you want to accomplish.
- show & shine bling bling
- performance & handling
etc.........
go fast=1/2" plenum spacer, headers, ztube w/kn panel filter, 18"Z track wheels, crank pulley, replace that 30lb premuffler with 22" resonator, and for better handling, drop car with Z suspension
bling bling=anything that looks chrome, 24" gigantor wheels that weighs 40lbs....each.
i can be just as fast as you can bling....
I am still not sure that many of those mods are worth the money. In many cases modded cars arent much better and, with suspension and tire changes, can actually handle and feel worse. I think the psychological effects move the driver more than the actual mods. Also, I question the engineering abilities of many aftermarket vendors.
I think a supercharger or turbo is worth money, but grounding kits and slightly raised plenums with shiny heat sucking intakes just dont seem right to me. (just my opinion, i know others love this stuff, and thats great)
I can appreciate the many modifications that everyone here does purely on a asthetical basis. I think I would feel the need to modify more if the midwest was crawling with g35's, but it isnt so g35's stand out already. (Acura TL's are everywhere, but G's are far and few between)
O, and make sure to post pictures of your ride and any interesting info about mods you performed.
for your case, maybe you should speak directly with vendors and ask them specifically why their mods work and hopefully they can provide before and after dynos........of course, we all know dyno #s can be manipulated ....better yet, find someone with mods you have doubt in and take a ride to see for yourself..........sure, some are for cosmetic like body kits that provide no real downforce or running neon lights under car.......i'm in the reducing weight and less rotational mass camp...... mods are listed in previous post
Don't do the headers for 200 bucks. You WILL be disappointed. Many companies have tried to make headers that work better than the stock manifolds. the cheapest is around 700 bucks and that was their 3rd or 4th attempt.
go fast: lighter wheels and tires, smaller diameter overall; lose the two 12"'s in the trunk; lose 20 pounds yourself and chop out the factor premuffler. after that: nothing (cept maybe some stiffer shocks). wait until you can afford forced induction. no other mod will be as cost effective as FI is.
research, research, research; many mods have lost power on the G's n Z's.
