Power Surge??
Old Sep 22, 2005 | 12:16 PM
Ragtops4fun's Avatar
Power Surge??
I've searched the thread and can't find anything related to this. When I'm driving, either freeway or local road, and gun it for a brief instant, the car will start to accelerate as I hit the pedal, decelerate when I back off, but then suddenly lurch again even though I have not depressed the gas pedal. Cruise control is not engaged. Is this delayed re-acceleration normal? I would have thought the initial shot of gas I gave would have been spent in the initial surge before I backed off. All of this happens within a few seconds. Was going to mention it at my next service interval. Example circumstance: want to pass someone, start to, but then notice the patrol car sitting in the median a half mile away.
Old Sep 22, 2005 | 12:31 PM
what2do's Avatar
Is your a 6sp? Sounds like it's down shifting. Never happens on my 05 but I know it does that on Acura automatic tranmission. Maybe reset the ECU next time you are in service.
Old Sep 22, 2005 | 12:39 PM
Thanks, What2Do...should have mentioned it's an automatic. I'm nervous about resetting the ECU based on what I've seen in this forum. People seem to be split as to whether you lose or gain performance and I'd hate to lose the performance I have...although I guess it would "relearn" it over time.
Old Sep 22, 2005 | 12:40 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
yeah, sounds like you're hitting that sweet spot in the shift points...I wouldn't worry about it. It's probably because our cars are drive-by-wire and the time it takes for it to recognize your input and implement is just long enough to cause the "surge" or shift change.
Old Sep 22, 2005 | 12:42 PM
a.k.a. RANDYS_G
you'll only LOSE power if you teach the car to drive like a grandma. My suggestion is, reset it, then go out and drive it like you stole it for 15 miuntes straight...then, the car should programs a more agressive map and you'll "find" power you didn't know you had.
Old Sep 22, 2005 | 12:55 PM
Thanks, Randy. Will give it a try this weekend.
Old Sep 22, 2005 | 12:59 PM
what2do's Avatar
Try it on manualmatic mode. See if it surges while you depress the gas in the same gear.
Old Sep 22, 2005 | 02:43 PM
Blackjack's Avatar
Heck Yeah! That's what I'm talking about. Go out and beat the **** out of her.. She'll learn. (only works on a car, not a wife )
Old Sep 22, 2005 | 02:53 PM
gtbigup01's Avatar
Any reason you don't want the dealer to address this? I mean it is a 04 and still under warranty right? Good luck.
vamarris
Sep 26, 2015 12:56 PM
zcherub
Sep 10, 2015 12:03 PM
