Finally hardwired my Bel RX65
Old Mar 29, 2006 | 08:06 PM
RXM's Avatar
RXM
Well, I finally got a chance to hardwire my radar detector. I've been wanting to do this for a while now but just wanted to think it through thoroughly what I wanted before I jumped in and it came out just how I wanted it. I'm planning on making a cover for the remote to fill the astray to make it look more professional. Some of you might be asking why I mounted the radar so high. The reason I mounted the radar so high behind the mirrow is because most likely I won't be tagged from the rear, I don't want people to be able to see it from the rear, and just because so no posts about where I mounted it...to each his own! For the remote, I actually had to extend the power wire that went to the fuse box and the ground wire as well. Total time to do the install was less than 1.5 hours. I don't know if any has attempted to place the remote in the astray before but man, its soo sleek
Attached Thumbnails Finally hardwired my Bel RX65-poweredon.jpg   Finally hardwired my Bel RX65-frontal.jpg   Finally hardwired my Bel RX65-open.jpg   Finally hardwired my Bel RX65-poweredoff.jpg
Old Mar 29, 2006 | 08:18 PM
BlackDiamond80's Avatar
that looks really good, i like it a lot, nice and clean, A+ with that
Old Mar 29, 2006 | 08:27 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Looks good. Now wipe down the rear view mirror
Old Mar 29, 2006 | 08:30 PM
Real_G's Avatar
An Army of One...
NIce install, you should mount the remote in a piece of plastic similar to this.Finally hardwired my Bel RX65-switch.jpg. in the ash tray..
Old Mar 29, 2006 | 08:31 PM
RXM's Avatar
RXM
I didn't realize how dirty my center console and rear mirror were until I looked at the pictures...I mean geeze....
Old Mar 29, 2006 | 08:32 PM
RXM's Avatar
RXM
Originally Posted by Real_G
NIce install, you should mount the remote in a piece of plastic similar to this.Attachment 37779. in the ash tray..
I was planning on doing just that and also adding an on/off switch while I'm at it. I'm going to have to tap into the ground wire to make the switch so hopefully its not too bad. I'm just happy with how it turned out
Old Mar 29, 2006 | 11:21 PM
JGFox's Avatar
I love my RX65 Pro but I don't know if I'd do a permanent install only because sometimes I unplug it when traveling with parents/clients/associates. Is it possible to remove the unit from the windshield so that it's just the connector wire sitting there or is it all completely and permanently attached? I wouldn't mind the wire there but the actual unit.. people start asking questions!
Old Mar 29, 2006 | 11:55 PM
RXM's Avatar
RXM
The power wire is "permanently" fixed to the car so that it powers on everytime I start the car. But the wiring is detachable so you can remove the unit to another car easily (the unit still draws power through the telephone jack located on the unit), just make sure u have the cig power adapter in the other car. I move the unit between my car and my sister's car. The only thing thats "permanent" about the hardwire is the power wire and ground wire, both of which can be removed from the car very easily if I chose to uninstall it. For the remote, I didn't drill through the the removable astray. I drilled through the actually astray thats part of the center console if that makes any sense. The reason I did that is because if I ever want to sell the car, I can stick in the removable astray and no one is the wiser.
KruZZe
Feb 27, 2023 05:04 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
