is it possible to watch dvd's on the 07's?
Old Dec 15, 2006 | 02:53 PM
  #31
ORANGEBSRT's Avatar
plain and simple it is unsafe but the dude this wants to know if its possible! Simple yes or no question. C'mon....everybody here does something that we know isn't right.....right? So cut the guy some slack!!
Old Dec 17, 2006 | 07:12 PM
  #32
Sedanman07's Avatar
Waxer
Ok played around a little today. To play a DVD there are two factors in place before you can watch it.
First the emergency brake has to be on. Well I was able to get around this. If you look there is a single wire/connector going to the emergency brake switch. By tapping into this wire as I did and grounding it the video will play without having to put the emergency brake on. However the brake light will be on in the dash. So best to do this with a switch and flip the switch to ground the wire only when you want to play the DVD.
That was the small issue. The second factor is the DVD won't play if you are moving. Putting the car in drive is not problem but as soon as you start moving just a few mph then you lose the video until you stop say at a light. So this will be the bigger issue to over come.
Old Dec 17, 2006 | 08:21 PM
  #33
DaCurryman's Avatar
I think I recall reading on some Lexus forum that the problem they have is that when the GPS detects movement, it disables the DVD source. I assume the issue you're mentioning is the same for us. I know that they're able to disconnect the GPS receiver or something to get around it. I don't know how difficult it would be for us.
Old Jan 9, 2007 | 07:55 PM
  #34
kewltea's Avatar
If it's related to the GPS/NAV, wonder if it'll work for people with Nav
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
alessandro
Oct 8, 2015 09:29 AM
