Opening the Trunk
Old Dec 12, 2006 | 04:22 PM
Garnet Canuck's Avatar
Traveling Administrator
Question Opening the Trunk
How are you guys opening the trunk? I don't mean unlatching the trunk, but moreso how do you lift the trunk lid up? My 03 had the doggy door on it so it was easy to lift up. So far I have been using my shirt sleeve and pushing up gently on my spoiler (not wanting to get fingerprints anywhere). Also, my fingers are too big to fit in under the lid at the very bottom. Just curious how you other guys are lifting up the trunk lid.
Pska's Avatar
i use the light on the spoiler, no fingerprints.
Old Dec 12, 2006 | 04:26 PM
07G's Avatar
07G
No spoiler here so I make sure my fingers are not going to slip when opening the trunk. In other words, carefully.
Old Dec 12, 2006 | 04:48 PM
DaCurryman's Avatar
I fit mine under the lid once I put the button and pop-it. I wish it flung open like on the MBs
Old Dec 12, 2006 | 04:59 PM
Christian's Avatar
Under the lid above the tail lights the opening seems to be a bit bigger, I've had good luck with it so far.
Old Dec 12, 2006 | 05:04 PM
GEE35FX's Avatar
I also wish the trunk would pop open a bit more when you hit the button, it does not leave much room to get your fingers underneath to lift it up. I thought there was something wrong with mine since it did not pop open more when you hit the release but it souns like it is normal.
Old Dec 12, 2006 | 05:05 PM
Blaxima's Avatar
Under the lid. You guys must have some huge fingers!
Old Dec 12, 2006 | 05:43 PM
G35Now!'s Avatar
Moderation-free
Guess I have skinny fingers, mine fit under the lip (no gloves required in Houston )
Old Dec 12, 2006 | 07:04 PM
wavelengths's Avatar
I lift from under the lid (between the bumper and trunk lid), and close using the handle. Only times I get fingerprints are when I'm like "whoops, that's not the opener button!" or when I don't get a chance to intervene before someone else tries opening the trunk!
Old Dec 12, 2006 | 07:10 PM
I must have stumps for fingers becuase I can't quite get my fingers under the trunk lid to lift it up.
Old Dec 12, 2006 | 07:17 PM
GEE35FX's Avatar
Same here, it is difficult.
Old Dec 12, 2006 | 07:49 PM
ABQ_G35's Avatar
Wayne, believe me, it's better it doesn't pop wide open, I know several occaisions where I came out and found it was popped, not obvious like if the lid popped open wider, that could be a problem in a parking lot! The spoiler is what I use on my '05 as well, nice handle!
Old Dec 12, 2006 | 07:50 PM
ABQ_G35's Avatar
And I know what it feels like to have a stump!
Old Dec 12, 2006 | 07:54 PM
LOL.
Old Dec 12, 2006 | 08:21 PM
RBull's Avatar
Rated M
Man, you're such a great sport Tom. Take care of that stump.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
vamarris
Sep 26, 2015 12:56 PM
