You CAN shut down car in drive!
Just an FYI ...
I was playing around this morning on the way to work and was wondering if the engine can be shut down in drive while in motion. Well, I pushed the button and nothing. I then thought I'd push it several times and guess what ... the engine shut down while on the move. I learned that
3 pushes of the button will shut the engine down, even if the car is on move.
Originally Posted by terrycs
Just an FYI ...
Good to know Terry. I guess that's a pretty good saftey feature.
Originally Posted by g35_6gear
With my 6mt it will shut down on the first push on a slow roll in neutral...but not over a certain speed.
EDIT:
For those of you that do not know ... you WILL LOSE hydraulic power to steering and brakes if the engine is shut down. You may only have 1 or 2 pumps of pressure in your brakes!
I only thought this would be helpful if for some crazy reason the drive-by-wire accelerator ever got stuck WOT.
Just thought I'd bump this ancient thread in light of what it going on with Toyota:
http://www.latimes.com/news/local/la...,5963897.story
Sorry man ... I'm not gonna experiment at 65mph
EDIT:
EDIT:
OK, let me rephrase that for those who need it... you lose brake assist/ brake booster/ vacuum booster (whichever you want to call it) at most. If you need to compensate for that loss of pressure, pump the brake pedal a few times really quick and your brakes will work like normal. All it really means is you need to use more force on the brake pedal. If that's too much work for you, then I really don't know what to say...
Of course, we can all think it through while typing on the PC. I'm sure if the poor guy in San Diego had time, he would have stopped the car. He was probably not familar with enough with it cuz it as a loaner.
Actually, the driver will have one or two full power stops available with the stored vacuum (use them wisely ). Pumping the pedal will cause the stored vacuum to go away faster. Once the motor is stopped and if it is safe to do so, try to keep the brakes on until the car is stopped.
The problem there wasn't that the car shut off and it wasn't a problem with anything electronic. The gas pedal was caught and stuck on the floormat and he couldn't step on the brake pedal because the floormat was in the way.
Good info Terry, thanks for the bump
^ yep.... drivers today (most) have no idea what it's like to drive w/o all the boosted/assisted controls.
....... IMO, if someone needs to rely on those things to drive, they need to go buy an old car without power steering, assisted brakes, or synchros and actually learn how to drive a car. Those things are great when you have them, but at least you know you can live without them too.........
