M Shift Knob
Old Aug 19, 2007 | 08:41 PM
rsx004's Avatar
Like the M, closer to the driver (left).
Old Aug 19, 2007 | 09:27 PM
Garnet Canuck's Avatar
Traveling Administrator
I think I'll do a little investigation on this. I really like the M shift **** much better than the stock one and wouldn't mind swapping it out. I'll let you guys know what I find out.
Old Aug 19, 2007 | 10:41 PM
rsx004's Avatar
Thanks, let me know if I can help.
Anyone know where to find the service manuals for both, we could probably start there.
Old Aug 19, 2007 | 10:45 PM
This is out of the G service manual. From the instructions, it looks like a 30 second job to remove the shift ****.
I am currently downloading the M service manual from here so I plan on taking a look at it.
Old Aug 19, 2007 | 11:14 PM
rsx004's Avatar
Looks to be fairly simple and I would imagine that the M will be close to the same. I think we are going to run into an issue with the ring where the shift boob meets the **** being a different shape on the M and G.
Old Aug 19, 2007 | 11:15 PM
rsx004's Avatar
Any wording to go with the G service manual?
Old Aug 19, 2007 | 11:16 PM
Yep, that might be the kicker for sure. There's gotta be a way though.
Old Aug 20, 2007 | 12:36 AM
rsx004's Avatar
Changing the shift boot would probably work. Both boots look very similar, just with different rings.
Old Aug 20, 2007 | 03:54 AM
G35PS's Avatar
Just buy ring off M and swap it along with shift ****.
You can keep the boot.
Old Aug 20, 2007 | 05:01 PM
bruddahmanmatt's Avatar
Originally Posted by logik05se
question for those with auto g's...to put it in tip mode is it like the M were you pull it closer to your body (left) or like the maximas were you push it further out to the right?
On the V36s the manual gate is located closer to the driver unlike the gates in the V35s and the FX which has the gate located away from the driver. Now if only Infiniti could figure out that it's supposed to be "pull for upshift" and "push for downshift" a la BMW, the A/T guys could finally rest easy.
Picture Share
Feb 4, 2018 12:41 PM
Tmatheso
Dec 13, 2015 03:24 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
