will the m45s shift knob fit on the 07 g35s
Old Jan 13, 2008 | 03:24 PM
  #196
Jason@Riverside's Avatar
Originally Posted by Lucky_One
is it possible to intergrate this M45 shift **** to 07G? and does it come in black?
i like this one better than the stiched one. thanks
I didnt notice this post before...
Yes, the M **** is available 3 different ways and will fit on any G with the automatic shift boot type...
This color, Solid Black w/ Black stitching, and Black w/ White Stitching (sport ****).
Old Jan 13, 2008 | 03:25 PM
  #197
Just a re-minder so do not have to go searching back into the thread:
Pricing!
Forum Member pricing for the Y50 Sport Shift ****!
Outside of California: $92.50
Inside of California: $99.31 (including Tax)
For all black or willow color, PM me zip...
Old Jan 13, 2008 | 03:48 PM
  #198
IvoryPearl07G's Avatar
jason, how much is G stock sport ****?
Old Jan 13, 2008 | 05:39 PM
  #199
07G35Socal's Avatar
Talking Shortened My lever Today
So I took the plunge today and took the dremel to my shift lever. Shortened my lever by about 3/4 inch.
I'll post some more later, time for lunch.
Old Jan 13, 2008 | 05:44 PM
  #200
Garnet Canuck's Avatar
Traveling Administrator
Looks great! Did you need to do anything other than cut white plastic shaft?
Old Jan 13, 2008 | 05:49 PM
  #201
JOKER's Avatar
CLUB MODERATOR
looks pretty nice.
will this work on the 05 coupe?
Old Jan 13, 2008 | 06:20 PM
  #202
07G35Socal's Avatar
I had to increase the 2 solts down the front and back side of the shifter, then cut the outer lever to the desired length.
Once the outside was short I worked on the inside. You can pull the white top off the metal pole.
For the inner pole that controls the shifting I cut it down to length.
After the shaft was close I worked on the white piece. I cut the bottom clip off and then shortened the top section. Took a lot of fitting to get both the center pole and the white piece to the proper lengths for perfect function. Used some hot glue to reconnect the clip and the top of the white piece.
Still need to go get some lube for the shaft and the white tip.
Old Jan 13, 2008 | 06:28 PM
  #203
07G35Socal's Avatar
Jason,
Don't bother cutting open a ****, they will not be able to be modified to sit lower. Heres a couple of pics of my **** (that doesn't sound right, LOL)
If you want to take a look inside one just stick a small flat head into the top side of the button, it pops right out.
Old Jan 13, 2008 | 06:32 PM
  #204
Awesome, thanks for the info. Would you mind posting this info in the DIY thread in the tech section as well?
Old Jan 13, 2008 | 06:37 PM
  #205
07G35Socal's Avatar
Done
Old Jan 13, 2008 | 06:38 PM
  #206
Thanks bro!
Old Jan 14, 2008 | 05:27 AM
  #207
G35s-Q8's Avatar
Originally Posted by 07G35Socal
Done
Can't find it in the DIY section .
Old Jan 14, 2008 | 07:23 AM
  #208
https://g35driver.com/forums/v36-diy/197345-diy-m45s-shift-knob.html
Old Jan 14, 2008 | 03:18 PM
  #209
yidster's Avatar
What about 6mt?
Now that I see this shifter, I want one for the manual...
I think that perforated black leather w/white stitching is looking great.
Anyone see shifters for manuals that look like this?
He2
Old Jan 14, 2008 | 03:41 PM
  #210
G35s-Q8's Avatar
PM sent .
