So...dealer gave me run around on timing advance
Originally Posted by g35sedan5at
today i went to a nissan dealer to have an oil change on my G and after the fact i quietly asked the tech if he could advance the timing on my car 2 degrees. he said no because since its a nissan dealership the computers dont work with infinitis and it wont work. this is bull**** considering the local guy who does it for 50 bucks works at a nissan dealer and uses his work diagnostic tool. ****ing jits, i woudlve given the guy 20 bucks under the table too. all for 3 minutes of pressing buttons.
Cost = $0.00 he hooked it up and did it free of charge!
Found this in the FSM, section EC-19
ITEM SPECIFICATION
Idle speed A/T: 650 ± 50 rpm (in P or N position)
M/T: 650 ± 50 rpm (in Neutral position)
Ignition timing A/T with 4WAS: 11 ± 5° BTDC (in P or N position)
A/T without 4WAS: 15 ± 5° BTDC (in P or N position)
M/T with 4WAS: 11 ± 5° BTDC (in Neutral position)
M/T without 4WAS: 15 ± 5° BTDC (in Neutral position)
So I guess stock timing is 15 degrees and the adjustment pushes it to 17? Just guessing/curious. I'm gonna bug my dealer too ;-)
I also found this:
Nissan Dealers can do the 2 Degree Timing Advance...
The 2 Degree Timing Advance can be done by a Nissan Dealer using the ConsultII or ConsultIII software depending on the year of the vehicle or by many others using similar software that modifies the vehicles ECU such as products by Uprev and Autoenginuity.
Dealer Instructions:
Two Degree Timing Advance Instructions (For Dealers w/ Consult II)
Warm up vehicle.
On CONSULT 2 screen choose ENGINE
After communication with Convertor will display a bunch of choices.
Press WORK SUPPORT
See more choices, press TARGET IGN TIMING
Press UP x2 for 2 degrees, correction which you should be able to see.
Press UPDATE.
Now press BACK
On the menu screen find IDLE AIR VOL LEARN.
Press, and perform to correct your idle since you just raised it 75rpm with timing advance.
Having these instructions in hand greatly increases the chance that your dealer will do it. Prices usually ranges from $0 - 1hr Labor.
~ Courtesy of adavis99 of TitanTalk
http://2degreeadvance.com/how.asp
ITEM SPECIFICATION
I also found this:
Warm up vehicle.
Press WORK SUPPORT
Press UPDATE.
Now press BACK
If the timing on this car is like the timing on any other car with a computer, it's not just a number (like 15).
Timing is calculated from a table based on RPM and load. There's a different timing spark advance for every different RPM and Load. Timing is higher at low load/low rpms and lower at high load, high rpms. On my heads/cam 2002 Trans am, I could run about 40 degrees during non load, 33 degrees at partial load, and 24 degrees of timing at WOT with no knock retard.
What will 2 degrees of timing do? You'll be lucky to get 2hp. But, if it's free.... why not? Just don't ever every use the lower octane gas after that. Premium only to be safe.
On the Trans Am, when it was closer to stock, 4 degrees of timing at WOT wasn't noticeable, but 5-6 degrees at part throttle was very noticeable.
My car will spend over 90% of it's running time below 4000rpm, so that is my focus. Advancing the timing even 2 degrees could give a noticeable (not huge, noticeable) difference at the low end. At WOT and high rpms, it could be a negative to peak hp.
I'm getting a feeling of deja vu
https://g35driver.com/forums/g35-sedan-v36-2007-08/184429-timing-advance.html
Had my timing advanced to 17 degrees BTDC yesterday at my friendly neighborhood Nissan dealer (less than a mile away; Infiniti dealer is farther). Cost me $50 (but they washed it too, so not too bad). I brought directions for using Consult II and Consult III, and he used Consult III.
Difference is subtle. Car seems to pull more strongly starting below 2000, before it didn't seem to kick in much until over 3000. Neck snapping ability seems to be enhanced too.
Or I could be hallucinating, but for $50for the timing advance plus having had the ITB-045 done previously, I'm very happy with the car now.
rezendvous420
05-31-2020 01:26 PM
joedaddy1
07-28-2015 02:58 PM
quickspeed6
24
07-15-2015 11:06 AM
