I cant stop!!
Old Aug 13, 2009 | 04:11 PM
bat6wc's Avatar
I cant stop!!
No this is a brake system related post...
I CANT STOP SPENDING MONEY ON THE G!! I have had a bad case of the mod bug and Im buying everything in sight.
Just order the Takeda Intake and the GT Spec strut bar. The car is going to be at the body shop late next week to get the TK spoiler installed and the nismo front lip fitted. I am taking the strut bar to the powdercoater as soon as I get it....going to make it all brushed aluminum finish.
I think ive worked the mod bug out of my system for now...
Old Aug 13, 2009 | 04:12 PM
I ride G's Avatar
now slam it =)
Old Aug 13, 2009 | 04:15 PM
bat6wc's Avatar
Believe me, I would love to but I have made up my mind and will only go with coilvers (if they ever come out for the AWD). Although, i have the eibach springs currently opened on my browser, just waiting for me to purchase. As much as I want to get the Eibachs, I just cant seem to let myself sacrifice the comfort for looks.
Old Aug 13, 2009 | 04:20 PM
Gr8speed68's Avatar
Buy a hooker there cheeper..lol
Old Aug 13, 2009 | 06:07 PM
beezy619's Avatar
Eibachs ride pretty much like stock and the drop is just perfect.
Old Aug 13, 2009 | 07:22 PM
J2S2M's Avatar
You not gonna feel much difference in stiffness w/ Eibachs. Trust me!
Old Aug 13, 2009 | 09:07 PM
Wes_888's Avatar
what about body roll? thats what I really wanna fix on mine.
Old Aug 13, 2009 | 09:08 PM
Wes_888's Avatar
hahaha +1!!! your not the only one...
Im about to sell my current rims to get a new set of rims... which will result in a drop... also im about to order new rotors & brake pads... and GT SPEC is almost certain as well... :S
I hear you man.. I hear ya... :S
Old Aug 13, 2009 | 11:02 PM
Lucky_One's Avatar
im in the same boat. however, the 4 inch clearance after eibach drop is holding me back.
Old Aug 14, 2009 | 12:48 AM
johnnyzee's Avatar
^ with an X, that will be your reality no matter what you drop with. the area under the front assembly sits low from stock (that's why our cars are a bit more jacked than the base model). Anything lower than eibach on an X, in my opinion, is asking for front end repairs.
Old Aug 14, 2009 | 01:11 AM
G35_RJ's Avatar
I have the dual CAI and Fast Intentions exhaust on my list, but I am afraid to pull the trigger... the window tint and clear bra already put a hole in the mod-fund
Old Aug 14, 2009 | 06:25 AM
Matchstickman60's Avatar
I say just wait for the coilovers because the Eibachs sags in the rear end which makes the front higher then the rear, so the car doesnt look as balance.
Old Aug 14, 2009 | 08:22 AM
Wes_888's Avatar
The problem with waiting on Coilovers for the X's is like... waiting for the cows to come home... :S
Old Aug 14, 2009 | 08:55 AM
soundmike's Avatar
Sways would really be your best bet, but i do realize there may not be one available for the X's yet. Does the GT-Spec rear braces fit though? Those work as faux sways, or rather existing sway reinforcements.
The Eibach's should also help, but not likely to be as much as the above. I can't get an answer out of Eibach on spring rates, so i'll just guess, that being a progressive spring already makes it slightly stiffer than the OEM's but gets moreso as load ramps up. You may get a bit of lean to start but will taper off and level out quickly.
Old Aug 14, 2009 | 09:52 AM
4drsleeper's Avatar
I understand the mod bug. Let's see:
Jan - Stillen HFC's and UR pulley, plus installation
May - Had to replace an O2 sensor
June - 19" Rims and Tires, Front lip
July - 370Z springs, plus installation
Aug - D2S 6000K's, T10 parking lights. Also had my exhaust wrapped.
It's been an expensive year so far.
