Gears slip. Revs up and jurks. Any HELP/clues?
Hey guys here's my problem. My gears on my 2007 G35s started slipping on the low RPMs/revs. What it does it just revs up little bit and then fall in the gear, so I get that jurk. It doesn't happen all the time, but it does happen pretty common. Usually when I slow down and try to accelerate it revs up and then jurks. Sometimes when that happens my SLIP light comes on and goes off really fast. I have no engine lights that are on on my car. I have no idea what that could be.
I checked my brake fluid and it's good. Reset the battery and it sill didn't help.
Any clues how to fix this or what might be causing this?
Hmmm sounds like too early for a tranny fail. Almost a brand new car.
I'm sure someone around had similar problem with their Gs.
so the car must be running while checking it?
Thebaws11
Jul 2, 2021 11:36 AM
