Oil Change?
Old Jun 15, 2010 | 11:42 PM
Nismo86's Avatar
Oil Change?
Never done one, where can I find what oil, how much and a video, write-up of someone doing it? I've seen the first gen video on youtube.
Old Jun 15, 2010 | 11:51 PM
blnewt's Avatar
It's really easy, just remove the back four bolts holding your plastic under-carriage shield, this will allow you to flip back the rear portion of the shield that will give you access to the filter & drain plug. You can hold the plastic flap open w/ a heavy object or wire it open. Fill w/ 5.2 qts of regular dino oil or switch to synthetic, it's up to you. I use Mobil1 5/30 w/ Mobil1 filters.
Changing the crush washer on your drain plug is optional. I never change mine and I've done about 8 oil changes on my old G35 & 4 on my G37.
Old Jun 15, 2010 | 11:53 PM
Nismo86's Avatar
What is the filter #?
Yeah I want to go with synthetic. So theres no 16 bolts like the first gen? That's the only reason I never did it.
Old Jun 16, 2010 | 12:08 AM
Shurik355's Avatar
Go to autozone and buy Mobil1 oil and the Mobil1 filter. Most places don't sell mobil filters so just go to autozone and buy everything there. I can't remember the filter #, but at autozone they can look it up for you. I think it's 108 something, can't remember for sure.
Old Jun 16, 2010 | 12:09 AM
Nismo86's Avatar
I was planning at buying at walmart, since where i'am thats my best bet.
Old Jun 16, 2010 | 02:34 AM
ultraman1017's Avatar
Purolator PL14610 PureONE Oil Filter (amazon.com) + Mobil1 0w-30 (walmart)
Old Jun 16, 2010 | 03:35 AM
J2S2M's Avatar
Mobil filter is M1-108
Old Jun 16, 2010 | 03:45 AM
E-Ticket Ride's Avatar
You can also use the Napa Gold filter #51356 = Wix = good
Old Jun 16, 2010 | 03:31 PM
terrycs's Avatar
I personally prefer to remove the whole shield. It doesn't take that long.
Old Jun 16, 2010 | 03:32 PM
J2S2M's Avatar
^1+
Old Jun 16, 2010 | 05:47 PM
Nismo86's Avatar
Is this the 16 bolts then?
Old Jun 16, 2010 | 10:11 PM
g37musings's Avatar
I use a bungee cord to hold the flap open. Works quite well.
Old Jun 17, 2010 | 09:04 AM
blnewt's Avatar
Taking the back 4 off, propping a hydraulic jack to keep the flap open, remove filter, drain & refill oil takes me about 20 minutes (driving up a couple ramps for clearance). Taking all 16 bolts off then having to reposition the whole shield and put back the 16 bolts seems like an extra PITA (and it gives me an extra 12 bolts to possibly cross-thread, lol)
Old Jun 17, 2010 | 01:29 PM
SCOOBY617's Avatar
ouo dont have to take off the whoe heat shield to get to the filet, there is an opening.. 2 screws and gives u full access to drain plug and filter.. f*** taken the whole shield off..
Old Jun 17, 2010 | 04:39 PM
LightsOut's Avatar
SIETESG
dont forget to remove the motor oil fill cap prior to draining oil.
