missfire?
Old Oct 4, 2010 | 07:33 PM
freakta's Avatar
missfire?
have a slight missfire between 35-40mph when the car is first start up. anyone have this issue? or can think of a cure
Old Oct 4, 2010 | 07:45 PM
jayk's Avatar
Did you just replace your sparkplugs?
Getting a misfire code? Specific cylinder or random on OBD?
Old Oct 4, 2010 | 08:00 PM
freakta's Avatar
no codes. no nothing really just a missfire at that speed. and only when its just started up, warm or cold doesnt matter. no codes. i havnt changed anything. i want to have some ideas before i into it. right now im thinking plugs and pvc to start
Old Oct 4, 2010 | 09:45 PM
kool_yaar's Avatar
do you think it could actually be the "shudder" all the auto guys are talking about at ~40mph instead of an actual misfire?
Old Oct 4, 2010 | 09:52 PM
jayk's Avatar
before you do anything i would check with an OBD. sometimes there are *pending codes.
Old Oct 4, 2010 | 11:45 PM
freakta's Avatar
ok ill check the obd first, and it could be a shudder. hmm ill do a search and see how they describe it
Old Oct 5, 2010 | 01:03 AM
tg1234's Avatar
yeap I am sure it is the shudder.
Old Oct 5, 2010 | 08:33 AM
RemmyZero's Avatar
+1 on the shudder. i can't envision a misfire without a code getting thrown, plus a misfire is unlikely to only present itself at that RPM/speed, typically a bad plug or coilpack will stay bad and cause issues all the time.
i would recommend installing the black betty grounding kit, i have had no issues since i put it in. also, consider telling your dealer and having your transmission control re-flashed. i don't know if that has resolved it for anyone though.
Old Oct 5, 2010 | 10:00 PM
freakta's Avatar
ok got a link to the ground kit
black_gst
Aug 15, 2014 03:56 PM
cass10169
Jun 22, 2014 04:02 PM
usmcgetsome
Sep 22, 2010 04:05 PM
Mark7
Aug 22, 2010 09:50 AM
kooguys racing
27
Dec 1, 2008 07:24 PM
