CD changer in truck => DVD player
Old Mar 1, 2011 | 06:52 PM
AesonVirus's Avatar
There's some old threads kicking around that showed people taking the CD Changers out.
It's a fairly easy task.
I never use mine...
A) It's a PITA being in the trunk
B) It makes the entry of the trunk too small for anything that would otherwise fit back there.
C) What the fvck is a CD?!?
Old Mar 1, 2011 | 07:11 PM
djfarhan's Avatar
just found these:
https://g35driver.com/forums/g35-sed...lacements.html
https://g35driver.com/forums/g35-sed...ger-trunk.html
Old Mar 1, 2011 | 10:07 PM
theophilus's Avatar
never even used that cd changer...i don't really know why you would unless you've maxed out the hard drive
Old Mar 1, 2011 | 11:30 PM
kool_yaar's Avatar
if you guys dont use it and need the extra space, then many have removed the cd changer and the covering and replaced it with OEM non cd changer trunk cover to get a wider trunk opening.
Old Mar 1, 2011 | 11:34 PM
salvador312's Avatar
I just like saying it has a CD charger!! That's about it! Other than that pointless!!
Old Mar 2, 2011 | 04:51 PM
terrycs's Avatar
I think it would be very cool if someone designed a full iPod integration solution using the existing CD changer harness. If I recall, track up/down signal is available through the harness.
Old Mar 2, 2011 | 04:56 PM
djfarhan's Avatar
^ whose up for the challenge!
Old Mar 2, 2011 | 06:27 PM
zoop425's Avatar
Is there a model that comes without it? / different liner? I took mine out and put a dvd player in. It was strait forward.. drop the liner, take out the changer, run rcas to center console, mount dvd player..
Old Mar 2, 2011 | 06:30 PM
djfarhan's Avatar
^ pics? diy thread? ;-P
Old Mar 2, 2011 | 10:13 PM
zoop425's Avatar
nope lol I took it out before I put in the xbox.. then I took that out.. decided to take my money out of video stuff and put it in to audio and performance.
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
alessandro
Oct 8, 2015 09:29 AM
1Typhoon
Sep 25, 2015 08:45 PM
