2nd Gen Random Little Question Thread!
Old Jul 2, 2013 | 05:09 PM
  #166
pwntu's Avatar
Originally Posted by vqsmile
I wouldn't expect the install to be difficult at all; it's just a module with plugs coming in and going back out. (Look at the pic in the ebay link) I can't say about your airbag light though, if it tripped because the connection was bad, then it may correct itself once the connection is fixed, but it could also, as a safety measure, require a formal reset to ensure it's working properly. I've seen this on other cars where if you if you compromise the airbag and then turn on the power, it locks a code in that won't clear with just another power cycle.
Thanks a lot for the help. I'm just going to take it to the nissan stealership and get it done. After breaking those plugs I don't feel very confident in my fixing abilities.. I'm probably going to get charged upwards of 500 but it was my mistake
Old Jul 2, 2013 | 07:04 PM
  #167
vqsmile's Avatar
Yeah, I'm sure that's gonna hurt a bit, but just think how insignificant $500 is, and how quickly you'd pay it instead of having a fractured face, no front teeth, and a severe concussion, let alone even worse! In the big picture, 500 bucks is R E E E E A L cheap when put it in those terms.
Old Jul 3, 2013 | 12:37 PM
  #168
pwntu's Avatar
Your absolutely correct. That money doesn't just fix the issue, it also puts my mind at ease when driving
Old Jul 6, 2013 | 02:46 PM
  #169
Mikey300's Avatar
What are the first steps in rebuilding my G35?
I just got my G35 and I want to make it sicker from the ground up inside out. Can anybody help me? Please and thank you
Old Jul 6, 2013 | 02:54 PM
  #170
vqsmile's Avatar
Yes, SOMEBODY can help you . . . YOU can help you!
Just browse around the forum a bit and use the search function. If you have specific questions about something in particular, and you can't find the answer by searching for it, then post a question and someone will more than likely be able to help you out. I'm not trying to be unfriendly, but this truly is a far better approach to learning about modding your car than just showing up and saying "Here I am, please help me by telling me what I would like on my car!".
btw, welcome to G35Driver Mikey
Old Jul 7, 2013 | 12:07 PM
  #171
herrschaft's Avatar
A Soup Kitchen will make it nice and sticky on the inside. Good tires is what you'll need for the outside.
Old Jul 10, 2013 | 01:01 AM
  #172
tomiwrap's Avatar
I've a G35X 2007 and i was wondering is there's some part i can use from a G37 that perfectly fit my model ? Like the light, bumper etc.. ?
Old Jul 10, 2013 | 03:27 AM
  #173
vqsmile's Avatar
It sounds like you're considering a front bumper conversion. Yes, it can be done. There are threads here describing all the parts needed and approximate costs. A simple bit of searching should turn up some results for you.
If you are not considering the full conversion, then no, you can't mix bumpers and headlights between them; they fit as a set.
Old Jul 18, 2013 | 09:27 PM
  #174
CFitz's Avatar
Has anyone experienced rain running off between the side of the hood and the top of the fender, into the headlight/headlight area? I believe that the rubber seal between the engine bay and the hood is not properly directing water, instead letting it dump onto my headlight!
Old Jul 20, 2013 | 08:23 PM
  #175
pwntu's Avatar
Just went to go check out OEM g37 sport 19's for my g35x sedan. 225/45 in front, 245/40 in the back. Will this fit on my car without problem? I know staggered fits sometimes cause issues with the AWD if the proportions are off. But, i dont know how to calculate. Also, will the tpms do good with my car? Thanks.
Old Aug 8, 2013 | 07:07 AM
  #176
VT's G35S Sedan's Avatar
Hello Fellas, as many of you know I used to post up pics of a Black G35S sedan.. then an F450 decided to run into me and its been sitting in my back yard since December.
Well recently I got another G35 sedan but this one is the regular journey and not the Sport.
Im planning on installing most of the interior parts from my Sport to this new one.
Has anyone installed a OEM Navi system in place of their Non-navi???
Installed the Sport seats?
Paddle shifters??
Old Aug 8, 2013 | 02:06 PM
  #177
b-dRizZy's Avatar
over on my G37 some guy was sellling the whole unit of the navigation and from what i heard theres about 2 guys outhere that have done the conversion, too much work and really not worth it.
but take a crack at it and do a write up i would love to convert mine to GPS
Old Aug 8, 2013 | 10:59 PM
  #178
I'll give it a try.. If anything I have the wiring from my original G35S sedan and might need to splice it into the new one with some wiring matching. My only option is to try and sell the setup and see if I get any offers
Old Aug 19, 2013 | 10:21 AM
  #179
pwntu's Avatar
Only the speaker in the back near the trunk has the bose logo on it, all the other ones do not. Does this mean that only one of my speakers are bose? Thanks.
Old Aug 20, 2013 | 03:35 AM
  #180
Gooniej12's Avatar
Has anyone replaced the chrome trim on the windows? Can't seem to find a DIY with some pics.
