Strange problem please help me
Old Jul 26, 2011 | 05:00 PM
GXXXV X's Avatar
On my way to work today something very eerie occurred... My radio and AC turned on high and the controls for both just stopped working! Luckily I was able to use the steering wheel controls to turn down the radio, but for half an hour I was forced to drive with the AC on high! I even pulled over half way, shut off the car and restarted it. It was fine for about two minutes and then it did it again!
Wtf is going on! Is someone remote controlling my car or wtf
Has anyone else had this strange thing happen to them??
Old Jul 26, 2011 | 05:01 PM
vp-g's Avatar
broke head unit
Old Jul 26, 2011 | 05:34 PM
rvanderwerf's Avatar
lol that is not normal
Old Jul 26, 2011 | 07:20 PM
kool_yaar's Avatar
a few ppl had that problem and ended up getting a new headunit under warranty
Old Jul 26, 2011 | 07:38 PM
GXXXV X's Avatar
O.O
My warranty ended in april
I'll see if theyll do it as a repair in good will or whatever, but as sad as it makes me I might just have to buy a DD 7 inch screen to replace it
Old Jul 26, 2011 | 07:40 PM
gtoor1990's Avatar
that happened 2 me with my previous coupe as well, it would randomly shut off then a/c would blast on high and be stucks like that for days
Old Jul 26, 2011 | 08:13 PM
SuperCleanG's Avatar
Sounds like time for an aftermarket touch screen set up
Old Jul 26, 2011 | 08:24 PM
PursuitofG's Avatar
i've experienced only the head unit freezing (cant control volume etc) turning the car off then on clears it up
Old Jul 26, 2011 | 09:46 PM
Sprockethead's Avatar
If turning off the car helps it, maybe draining all electricity might help "reset" whatever the problem is. I mean by unplugging the battery and leaving the lights on for a while, and then hooking it back up. I have no idea if that makes any logical sense because I'm not a mechanic, but that's something I would personally try since it would be so easy to try.
Old Jul 26, 2011 | 11:09 PM
GXXXV X's Avatar
thanks i will try next time it does it but on my way home it didnt do it...?
Old Jul 27, 2011 | 08:54 PM
GXXXV X's Avatar
I tried this today and did not have any problems with it yet! Knock on would! Lol
Old Jul 27, 2011 | 09:13 PM
gtoor1990's Avatar
^^ Hopefully it works well !
Old Jul 29, 2011 | 10:07 AM
GXXXV X's Avatar
No problems so far! i have no idea how but IT WORKED!! THANKS Sprockethead!!
G35xdriver04
Nov 7, 2015 08:31 PM
G35-R
Nov 7, 2015 01:21 PM
mattdg35
Sep 14, 2015 11:28 AM
pasjr1972
Sep 1, 2015 10:17 PM
