Dealership Made a Mistake... Never!
Old Oct 28, 2011 | 05:52 PM
Naif2's Avatar
I just brought my 07 G35s back into the dealership after getting my transmission oil changed (6MT) for having difficulty shifting gears after getting the transmission service done. As soon as I sat down my adviser mentioned they put a heavier weight oil in by mistake.
My question is, will this have any long term issues with the syncro's or Transmission? I have driven roughly 500 miles with the wrong oil.
Old Oct 28, 2011 | 07:53 PM
JDMPenn's Avatar
I would assume the transmission got worn out faster then usual. Did they do you any courtesy by at least looking at the transmission afterwards?
Old Oct 28, 2011 | 08:11 PM
bluedevils95's Avatar
I say you take it back and have them fix it
Old Oct 28, 2011 | 08:26 PM
vqsmile's Avatar
Assuming you weren't experiencing massive gear clash/grind while the thicker oil was in (just sticky and cumbersome shifting), and if it's working properly after swapping in the proper thinner oil, then I would say NO, I don't think you'll have to be concerned.
I can appreciate how irritating it must be, but I seriously doubt in the long run you'll notice any slight wear difference caused by the mixup.
Old Oct 28, 2011 | 08:48 PM
Triton3.5's Avatar
whs.....^
Old Oct 28, 2011 | 11:21 PM
MPohio's Avatar
500 miles of "normal" driving shouldn't have hurt anything, but keep an eye on it for leaks and abnormal behavior. Plus, start searching for a better service center
Old Oct 28, 2011 | 11:33 PM
HenryLee's Avatar
You will be fine. But i wouldnt be going back to that stealership.
Old Oct 29, 2011 | 12:28 AM
I would go back. They made a mistake and they need to fix the problem on there dime
Old Oct 29, 2011 | 12:48 AM
dota-lina's Avatar
i thought infiniti&nissan dealers will use nissan ATF for everything,how do they use different oil? they put gear oil in it instead?
Old Oct 29, 2011 | 12:57 AM
vqsmile's Avatar
Not everyone drives an automatic.
Old Oct 29, 2011 | 01:22 AM
thescreensavers's Avatar
Mr.202?
^ ATF is and stands for Automatic Transmission Fluid
Old Oct 29, 2011 | 11:00 AM
dota-lina's Avatar
how stupid it is for the dealer to put mtf or gear oil into atf, lol. they must been drunk.
Old Oct 29, 2011 | 11:58 AM
vqsmile's Avatar
Uhmm....Guys, as I read the OP's post, he's says he's got a 6MT. Where are you all getting this whole ATF issue from?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Learned Hand
Oct 1, 2015 09:02 AM
