Having rough Idle problems car shaking?
Old Dec 6, 2011 | 10:59 PM
sdonabo's Avatar
Exclamation Having rough Idle problems car shaking?
If your car is having idling problems,shaking when parked or at a red light?
This tread could problably help.
My car was having rough idling,so i decided to clean my throttle body and mass air flow sensors now my car is running like a champ,it fixed the rough idle.the car dosnt shake anymore and the engine sounds very smooth when its on,kinda like when its new?
You have 2 be really carefull when doing this procedure.be carefull not to let the throttle slam shut,disconect the battery while doing this,and dont over tighten the screws on the mass airflow sensors.use crc throttle body cleaner and crc mass air flow cleaner from autozone let it dry for like 45 min.The mass air flow sensors are connected to the air boxes or air intakes they only have 2 screw.The throttle bodys only have 4 bolts.
just take off screws form both parts dont disconect wires.
Theres a DIY thread on the throttle bodys
but none on the mass air flow sensors
This is only a suggestion
it worked for me,if done correctly you shouldnt have any problems
I hope it helps you guys
Old Dec 7, 2011 | 09:38 PM
sdonabo's Avatar
did it help any 1?
Old Dec 9, 2011 | 01:16 AM
sdonabo's Avatar
let me know if you guys try this
Old Jan 15, 2012 | 04:44 PM
heiltrading's Avatar
ruff idle and p0300
my car has 20,000 miles and have an idle problem as you described. do you think at this low of mileage i would need to do this?
Old Jan 15, 2012 | 05:18 PM
vqsmile's Avatar
What year is your car? If it's still under warranty, let dealer fix it.
Regardless, you have an actual fault code (for misfire if I recall correctly), so you should pursue that rather than cleaning intake tract. Misfires are usually electrically based and not from a dirty intake.
Lots of info available for troubleshooting codes. Search is your friend.
Old Jan 15, 2012 | 06:14 PM
RedBaronK's Avatar
Clean ur throttle bodies.
Old Feb 2, 2012 | 06:25 PM
jobyc1's Avatar
07 g35s 55k
rough idle/shaking
How I fixed it:
1. had throttle body cleaned
2. fuel injector treatment... slightly better
3. MAF and PCV cleaned/ checked
4. throttle body removed and cleaned behind .... WORKED!!!
Old Feb 3, 2012 | 12:23 PM
thundercracker's Avatar
anyone ever get their tb's cleaned at a mechanic, and how much would this cost? i have 2 little kids, and zero time to be pulling stuff apart.
Old Jun 19, 2012 | 04:01 PM
jobyc1's Avatar
Originally Posted by jobyc1
07 g35s 55k
rough idle/shaking
How I fixed it:
It came back! time to check injectors I guess?
Old Jun 20, 2012 | 11:48 PM
so to answer my own question, had my tb's cleaned by a nissan dealer, $150. i dont think they pulled anything apart, rather ran some type of cleaning fluid through. called it a fuel system service, and the rep said it would clean the tb's. so far the car does run smoother, less rough idling, smoother acceleration. i hope i didnt get soaked..
chinee
Jun 10, 2024 07:48 PM
champppy
Mar 31, 2020 12:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
itschuckster
Jul 25, 2015 08:07 AM
