Infinity Basslink and Bose system
Old Dec 31, 2011 | 08:04 PM
mroadster2k's Avatar
Guys, is there an easy way to install an Infinity Basslink subwoofer on a Bose system? The stock Bose system on the '08x sounds great at low to medium volume, but it distorts when the volume increases. I'd like to be able to either add the Basslink to the setup, or bypass the stock subwoofer altogether.
I'm thinking of just bringing it to Best Buy and have them figure it out.
Opinions?
Happy New Year!
Old Dec 31, 2011 | 08:54 PM
G3Sx's Avatar
I ran the BassLink in my previous car (a wagon) and while it improved the low end, I'm guessing it won't have as good of an effect in a sedan where it will have to fight to be heard through the rear deck. As far as installation, it shouldn't be any different than a regular amp install. Its amp accepts both, low and high level inputs. You will need a 10 gauge wiring kit with a 20 amp fuse. Be sure to tap into the pre amp wiring of the Bose system. See my Sub Install Thread
for diagrams that show where to tap into the factory wiring for signal and remote turn on.
I do warn you though, when it comes to audio (much like horsepower) it usually feels and sounds great the first few times before more often than not you end up wanting more. If you think you may want to upgrade later, then run a larger wiring kit so you won't have to do it again. A 4 gauge kit should give you enough room to handle 750 to 1000 watts RMS depending on amp efficiency. Good luck and Happy New Year!
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
Daniel k.
Nov 3, 2015 09:52 AM
Tyler's03G
Aug 13, 2015 10:04 AM
Frostbite91
Aug 2, 2015 04:59 PM
